351W SBF rookie build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-15-2012, 05:58 PM
Skip white anyone?
Mustang671 thanks for the words, I appreciate every comment, I can't wait to fire it up! But I still have to pay my college loan so I'll have to take it easy... I'm leaning towards KB hypers and ss magnum rollers.... What I don know is the ratio f the rocker 1.6 vs 1.7, I'm still a little confused with this parameter. I'll have to read up on it.
Looking around to cut the budget I ran in to skip white performance, after a Couple of searches it seems they have decent stuff, at least for street performance.
I was looking at getting a set of aluminum heads which would almost cost the same as the stock (after porting and valve train upgrade)... Any feedback on these? Has anyone used them before?
Thanks!
  #17 (permalink)
Old 11-15-2012, 06:13 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Originally Posted by Irelands child View Post
You have no gain by using steel roller tip rockers which retain the sliding fulcrum. You may also get into push rod length problems whereas the standard sliding tip aren't so fussy as to where they land on the valve tip
Times 10,000.....thank you.
  #18 (permalink)
Old 11-15-2012, 06:28 PM
Anyone else used aluminum roller rockers from skip white? They said they were comp rollers ¿? They have a lifetime guarantee...
  #19 (permalink)
Old 11-16-2012, 01:22 PM
Cylinder heads
Looking at the cam and money that would be spent on porting heads and new valvetrain Im considering a pair or aluminum cylinder heads... I know I dont have the cash for AFR or trick flow but what affordable make would you recommend??
Im looking at:
Dougherbert cylinder heads
Skip white cylinder heads
They would be assembled for the solid roller .605 lift
Any other budget friendly recommendations? or feedback on these?
  #20 (permalink)
Old 11-16-2012, 03:59 PM
vinniekq2's Avatar
make sure you want to go the big cam route? Then look at the 600 lift cam and find heads that flow the numbers you need to make the horse power you want.Choose parts from there.That cam will make this engine a high rpm performer
  #21 (permalink)
Old 11-16-2012, 04:11 PM
Both skip white and dougherbert heads have the and flow required for the .605 lift...
I'm leaning towards the dh but googling around its seems skipw aren't so bad also... They aren't afr or top quality but i believe they will surpass original cast ported heads.
Which would y'all recommend?
  #22 (permalink)
Old 11-16-2012, 04:42 PM
vinniekq2's Avatar
I use dart heads,never bother with skip white when I heard all the complaints.Sometimes cheap parts are ok...Ive used edlebrock heads on budget engines and dart cast iron heads. maybe buy cheaper castings and install premium valves and use the springs from the cam company
  #23 (permalink)
Old 11-18-2012, 01:56 PM
mustang 671's Avatar
your welcome.
i have the alu edelbrock victor junior heads with 2x valve springs and triple angled valve seats. think they are a affordable head i feel . work well for me .
Edelbrock Victor Jr. Cylinder Heads 77189 - SummitRacing.com
  #24 (permalink)
Old 11-18-2012, 03:14 PM
Senior Curmudgeon
Wiki Edits: 326
Thanks Vinnie, I think that's the answer. It seems that the problems with those offshore heads that Skip White sells were layin' down because of inferior parts used to assemble them, not necessarily in the casting itself.
  #25 (permalink)
Old 11-18-2012, 09:28 PM
Wishlist
So after some reading and googling around, I put up a wishlist... I dont want my engine to blow for a couple hundred bucks I didnt spend so maybe I'll take the build slow so i can save some money in between... Anyways take a look and give me some feedback please!
Dart SB-Ford Pro 1 Aluminum Cylinder Heads
Scorpion Race Series Rocker Arms
KB Signature Series Hypereutectic
Moly Rings 1/16'', 1/16'', 3/16''
Carburator Edelbrock 750 cfm NON EGR, maunal choke
RPM Air gap manifold
Mehcanical Fuel pump 110GPH
High volume oil pump
High volume mechanical Water pump
Mallory Promaster Series Distributors 8578M
MSD 6A ignition box
MSD blaster 2 coil
Details on the heads>>
SB-Ford
Intake Ports: 170cc
Combustion Chambers: 62cc
Valves: 1.94" Int/1.60" Exh
Angle Plug
SPECIFICATIONS
Block: Iron or aluminum Ford
Valvetrain: Roller rockers 3/8" or 7/16" stud mount
Intake Port Location: Stock
Intake Port Dimensions: 1.980" x 1.100"
Intake Flow: 261 cfm @ .600" lift/28"
Intake Gasket: #375-1262
Exhaust Port Location: Raised .135"
Exhaust Port Dimensions: 1.330" x 1.340"
Exhaust Flow: 172 cfm @ .600" lift/28"
Exhaust Gasket: #375-1487
Manifold: Most with standard port location
Pushrod Length: Please measure
Pushrod Guide Plate: #249-4816-8 (flat)
Retainers: Steel
Stud Girdle: Any standard girdle
Valve Length: 4.890"
Valve Stem Diameter: .3415", 11/32"
Valve Guides: 1/2" OD Mag-Bronze (.002" press)
Valve Guide Length: 2.250"
Valve Guide Clearance: .0014" to .002" (using Dart .3415" valve stem)
Valve Guide Spacing: Moved .050" from stock
Valve Seats: Hardened Ductile Iron, .006" press
Valve Seat Dimensions: Intake 2.160" x 1.750" x .350", Exhaust 1.650" x 1.350" x .350"
Valve Seat Angles: Intake 32°, 45°, 60°, 70°; Exhaust 37°, 45°, radius
What do u guys think??
[[Meanwhile in my wallet>>]]
  #26 (permalink)
Old 11-18-2012, 09:42 PM
vinniekq2's Avatar
you have a good start on your wish list. save a few pennies,,, when you are close to buying,contact a couple places before buying and go to an engine builder as they can sometimes give a really good package deal
  #27 (permalink)
Old 11-18-2012, 09:48 PM
Ok! thanks vinnie! I was comparing prices between jegs and Summit (pretty much the same), when Im close to ordering I'll try to get a deal, I'll also give dougherbert a call since they handle the parts and I would think are easier to deal with giving they are a smaller company... but whoever gives a better price, shipping charges and customer care will win me over
  #28 (permalink)
Old 11-18-2012, 10:00 PM
vinniekq2's Avatar
when I was figuring my engine( I changed my mind several times) I started pricing parts,then up graded,then decided on a stroker,,,,,etc etc.then I priced out all the suppliers local and mail order. Then I talked to specialty companies. Jeff Lukovic could sell me the parts and do the machine work for me cheaper than I could buy the parts locally.I ended up buying most of my engine parts from him.I ordered the MSD locally and carb (second carb) came from the carb shop,the headers were custom built by Jere Stahls shop,took lots of research,so do not get discouraged,keep in touch here and keep asking questions,,,,because after your project is done you will be helping the next ford guy thats doing what you are doing now
  #29 (permalink)
Old 12-11-2012, 11:12 AM
choosing the right heads
Hi everyone,
Im back with my head spinning around choosing the right set of heads for the setup...
The intake manifold is going to be a Ford Racing Dual plane 1500-6500RPM...
Looking around I have it down to 3 options:
Dart 13211112 - Dart SB-Ford Pro 1 Aluminum
  • Intake Ports: 195cc
  • Combustion Chambers: 62cc
  • Valves: 2.02" Int/1.60" Exh
  • Intake Port Location: Stock
  • Intake Port Dimensions: 2.000" x 1.125"
  • Intake Flow: 288 cfm @ .700" lift/28"
  • Exhaust Port Location: Raised .135"
  • Exhaust Port Dimensions: 1.350" x 1.350"
  • Exhaust Flow: 185 cfm @ .700" lift/28"
Dart 13111182 - Dart SB-Ford Pro 1 Aluminum
  • Intake Ports: 170cc
  • Valves: 1.94" Int/1.60" Exh
  • Intake Port Dimensions: 1.980" x 1.100"
  • Intake Flow: 261 cfm @ .600" lift/28"
  • Exhaust Port Dimensions: 1.330" x 1.340"
  • Exhaust Flow: 172 cfm @ .600" lift/28"
AFR - Airflow Research 1399 - AFR SB-Ford Outlaw Street/Race Aluminum
  • Combustion Chambers: 58cc
  • 165cc Intake Ports
  • Intake Valve, 1.900'' Stud Mount
  • Exhaust Valve, 1.600'' Stud Mount 58cc
What would you recommend? I have doubts regarding the Intake ports (cc), combustion chamber (cc for compression reasons) and quality DART vs AFR ¿?
  #30 (permalink)
Old 12-11-2012, 04:16 PM
vinniekq2's Avatar
dar and AFR are both quality products.If you need the money for school then thats your best long term investment.
The smaller heads are plenty,depends on the h p you need?
The Following User Says Thank You to vinniekq2 For This Useful Post:
celamb89 (12-11-2012)
351w, sbf, windsor build
First SBF build.. 347 zildjian4life218 Engine 9 01-23-2012 03:14 PM
My 351W sbf 1405 tune-up data 001mustang Engine 0 05-24-2009 04:51 PM
Need to build a 351w madesen Engine 1 04-25-2007 09:49 PM
Hotrodders rookie but not a Hot Rod Rookie Mic Mercer Introduce Yourself 5 01-22-2006 09:27 PM
Need help with a 351W build Nico Engine 6 06-15-2003 10:07 PM
