Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 04-12-2005, 03:14 PM
PHATHOM's Avatar
PHATHOM PHATHOM is offline
My wife said no more hotrods..
351w Set-up
I recently started on a 351w for a 79 ford f150. Convertions are as follows: holley 650 4 bbl with a ford 351w iron 4bbl intake, 266 / 488 comp cam, heads by JCS (hich I believe if jesus had a hotrod it would have these heads on it). The problem..it runs like crap. I set up cam timing notch to notch and tried ignition timing 6 ways to sunday. I am using stock ignition set and a dual vac distr. I am getting a bad case of pre-ignition detonation under load. Exaust is clean and compression is good (stock cylinder, ring and piston size). I am going to crack back into the timing cover and see if anything jumps out. In the meantime, any ideas out there?
Old 04-12-2005, 05:33 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Balanced with heavy metal
re: 351w Set-up
Lose the iron 4 bbl intake, they are terrible for distribution.
Old 04-12-2005, 07:48 PM
Max Keith's Avatar
Max Keith Max Keith is offline
Running like crap
Im wondering if you are running the correct firing order. you Check the firing order on the cam card, and make sure you are running the correct one.
As for the stock 4 bbl intake, they arent the greatest, but they will get the job done.
Old 04-12-2005, 08:10 PM
PHATHOM's Avatar
No misfire at idle..
...And I don't have the data card for the cam. Is it presumtuous of me think the stock firing order would be incorrect? I have done this before with my 66 mustang (289 hipo)...just change the cam, intake, carb and exaust for a little performance...and it runs like a raped ape. As for the old iron intake, lol, I hate it when aluminum warps when it gets too hot....lol.
Old 04-12-2005, 11:10 PM
Max Keith's Avatar
Presumtions
Well as far as the firing order being changed, its not really presumptious, but the sad fact is a lot of cams that are sold for 351W do have the 289/302 firing order. Ive made that mistake myself, and I am far from no genious on that stuff. That is why I brought it up. It is an easy mistake to make.
What is the grind number on that cam? I dont see it in my Comp Cams book, at least not with that advertized lift and duration.
Old 04-13-2005, 04:52 PM
PHATHOM's Avatar
cam and timing
Ok, I pulled the timing cover and valve covers off and checked valve timing to ignition...13726548...they match. I am thinking of ditching the dual vac dist in favor of a single vac and going to points instead of electronic (yes, I am an old man). At this point I am pretty sure this is an ignition issue...anyone second this opinion?
Old 04-13-2005, 07:34 PM
Max Keith's Avatar
vacuum distributor
All you need to do it just disconnect the vacuum hose nearest the distributor cap and plug off the nipple, and also plug the vacuum line nipple on the vacuum manifold the hose ran to. The rear vacuum line only works when the enigine is cold, allowing it to prevent the vacuum advance from working, thereby causing the engine to warm up faster. One of those genious ideas for polution control that all the auto manufacturers foisted on us back in the 70's to buffalo all the idiot lawyers writing silly regulations.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "351w Set-up"
Where to get a set of Unilug washers and nuts to fit? Dubz Hotrodding Basics 1 07-06-2004 07:33 AM
Starting different after timing set? frankenvette Engine 1 06-30-2004 09:49 PM
Using Wheel Scales To Set Preload BillyShope Suspension - Brakes - Steering 8 04-20-2004 06:35 AM
351w variable vent. distributor swap Jared Engine 0 10-07-2003 09:54 PM
never set up a dual point, looking for help! HotRodF100 Engine 11 02-19-2002 02:44 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
