hey all if i have a 351w bored to 4.030 with a 4.250" stroke, 6.250" rod length, and a compression distance on the piston of 1.100" how do i determine the push-rod length without buying the checker? I want to run 1.6:1 or 1.72:1 rockers but don't know how much room I have to play with. What style and thickness of head gaskets would I need for safety on the valve to piston clearance it has a stock deck height and unmolested patriot heads, by the way this is my first stroker and by advertisement it is suppose to be 434c.i.d. I would like to have it together by spring if money permits. It has patriot heads and a professional products upper and lower intake with 70mm m.a.f. and 5 speed manual with 3.73:1 to start out, I might go with 4.11:1 later got to drive it first and see. Any help would be great on push-rod length and rocker arm size anything really Thanks
