Thread Tools Search this Thread share on Facebook
  #1
Old 02-07-2009, 07:03 PM
ericdavis2207 ericdavis2207 is offline
351w swap
I have a 89 bronco just bought a few days ago. Well needles to say the 5.8 351w that needs to be rebuilt or replaced. Well I found a guy that has a 351m out of a 79 bronco for $300 runs and doesn't smoke. will the 351m fit right in inplace of the 351w? Its me and the kids play truck so don't need anything crazy in HP just needs to go forward. Thanks in advance for all your help.
Eric Davis
Register now (free) or login to remove ads
Old 02-07-2009, 07:38 PM
onebadmerc's Avatar
onebadmerc onebadmerc is offline
I need a bucket of arc sparks
To answer your question,NO a 351M will not bolt in where the 5.8 resided. The 351M has different motor mounts and a bell housing pattern. The 89 5.8 is fuel injected, Ford never made a fuel injected 351M. Fuel injected engines use different wiring than carbed engines,which mean wiring changes. What you are proposing is taking a step backwards in performance,fuel economy, and reliability. Forget the 351M and find a good running 5.8 or 5.0 and swap out your tired engine for one of these engines.
Old 02-07-2009, 07:47 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
you can always tear down and take a look at your 5.8 thats in the bronco.does it run now?
Old 02-08-2009, 12:04 AM
It did run just got the engine out tonight, but it would barely push its self. And I had it checked and they said it had less than 100 psi compresion.
Old 02-08-2009, 12:26 PM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Although I don't think you would have that much trouble putting the M in the truck with stock parts( you will need another tranny), I agree with repairing the one in it. The fuel injection system alone makes the power better than what the carbed 351M produces. They are a little anemic in stock form...to say the least.
Old 02-08-2009, 09:49 PM
I found a local guy that said he would rebuild it for $1500 and I asked around people have said that he is good. He also told me he would put an RV cam in it for better low ebd torque.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "351w swap"
ThreadThread StarterForumRepliesLast Post
351w c4 to c6 swap possible?7StangG2Transmission - Rearend4305-19-2009 07:32 AM
351w distributor swap problemsJaredEngine201-08-2009 09:01 AM
351w O.E.M. parts swapborntorace80Engine1809-03-2007 06:55 AM
351w variable vent. distributor swapJaredEngine010-07-2003 09:54 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
