Thread Tools Search this Thread share on Facebook
  #1
Old 01-24-2009, 07:30 AM
ol'black 52 ol'black 52 is offline
351w thermostat housing woes...
Can't keep thermostat housing on my 351w from dripping...have removed nipple and sanded on piece of glass as recommended. Using Indian head gasket gooo ....any thoughts??
Register now (free) or login to remove ads
Old 01-24-2009, 09:17 AM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
are you running a stock or an aftermarket housing.
Old 01-24-2009, 09:44 AM
351w thermo housing...
Thanx for replying...I am running a chrome after market housing. I have already eliminated the chrome from the flange side that bolts to the intake manifold and re applied three new gaskets with the same drip !!
Old 01-24-2009, 11:42 AM
eloc431962's Avatar
Wiki Edits: 37
i have run into the same problem before.what i did was took out the rubber o ring.if this is the type you have and i sanded it down where it mates to the intake.and then used a regular gasket from a stock thermostat.but if you dont really have to have chrome it is best to find orignal housing it always works for me.i usually wind up with the chrome one on the shelf.by the way your thermostat is it slipping out of pocket causing the leak.hope this helps. cole
Old 01-24-2009, 01:10 PM
red65mustang red65mustang is offline
triple check that the bolts are not botteming out!!!
after market flange maybe thinner than the original...
use a magic marker to color the seal surfaces and then use a broad flat file to expose a virgin clean surface for the gasket/gasket sealer to grab
(to know there is no silicone)
Old 01-25-2009, 12:18 AM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Stock gasket, rough surface finish on the housing, file manifold side flat, non-hardening sealer on the gasket (I like 3M spray gasket). Let set overnight, do not overtorque.
Old 01-25-2009, 08:39 AM
FASTFORD's Avatar
FASTFORD FASTFORD is offline
many of the after market chrome housings are NOT flat on the mating surface.
my experience with these was the same. I removed the chrome,filed,sanded the mating surface & re-installed.
after 3 or 4 heating/cooling cycles it was leaking again. the housing warped.
installed factory unit...problem solved.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
