We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 07-04-2009, 05:34 AM
eric866121 eric866121 is offline
351W Timing marks & 408 clearance question
Hey Ford guys, I'm a chevy guy helping my Brother-n-law build a 408w. We are using a Cloyes True roller timing set and there is no defined timing mark (dimple) on the crank gear. There is the 3 key way locations for cam timing and I'm putting the cam in at zero. I’m assuming that the key way “O” is the crank gear timing mark that should be at 12’ 0 clock and the cam gear dimple is at 6’O clock.
We are building a 408w (eagle crank, eagle h rods, probe pistons) with AFR 185 heads. Are there any rotating assembly clearance issues that need to be checked (rod to cam, etc)?
Old 07-04-2009, 11:41 AM
help
Anyone......?
Old 07-05-2009, 12:43 PM
Please>>>>>
Please.........
Old 07-05-2009, 01:33 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
eloc431962's barnstar
Wiki editor
Last wiki edit: Hand cleaner
Wiki Edits: 17
Bring it up on #1 the crank key should be straight up.The cam gear should have a dot on it. when you get the crank key way straight up and the dot on the cam gear straight down lined up with the key way put the chain and gears on it should be in time. You can adjust it out with the distributer after it fires up. Just remember the top gear the dot goes down lines up with the crank keyway as far as the three locations thats for advance and retard i always put mine in the middle dependes on what your buddy is doing with his ride race/street . Hope this helps. Cole
Old 07-05-2009, 02:24 PM
RippinRon's Avatar
RippinRon RippinRon is offline
All the clearances will need to be checked out. Never assume the rotating assembly is good to go out of the box.
Old 07-05-2009, 02:51 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
techinspector1's barnstar
Wiki editor
Last wiki edit: Threading tips
Wiki Edits: 210
I don't know if this is voodoo or not, but may solve the problem of how and where to clearance on the block. Just doing some googling for you....
http://www.themustangdepot.com/serv...learance/Detail
Here's a better visual of such a tool in use....
http://www.hawksracing.com/347strokerinst.htm
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "351W Timing marks & 408 clearance question"
sbc timing question stepj19 Engine 3 04-21-2009 08:02 AM
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 03:49 AM
Ok Sorry Another Timing Question funbiz99 Engine 13 04-23-2007 10:14 PM
Timing mark question Kevin45 Engine 4 07-12-2005 06:46 PM
timing question 85 vette Engine 11 12-17-2004 07:27 AM
