02-21-2013, 12:15 AM
Originally Posted by stewd8
hi guys, 351w problems i need help with.....the rocker wants to turn, forcing the push rod against the pushrod guide, wearing the pushrod in 1 miniute,,,then it bends,,,,
this is a fresh motor that i just built, the cam is a comp cam 06318
grind is xe268h,,,,its suppost to be prity lumpy, stock pushrods and rockers,,,any ideas
Stock pushrods?  Stock valve springs?  Order the Comp pushrod to check for proper length,you have a couple of ways to go you can order the correct length pushrods or get the shim kit http://www.summitracing.com/parts/crn-99170-1 for your rockers or get a good set of heads with screw in studs so you can run adjustable rockers.
