Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 351w valve train
Old 02-21-2013, 11:49 AM
MouseFink MouseFink is online now
If your 351W has self aligning rail type rocker arms, you must use valves with .395" tips.
If your 351W does not have self aligning rail type rocker arms, you must use valves with .250" tips.
Make sure the valves are the correct type for the rocker arms you are using. Using valves that have .250" tips with self aligning rail type rocker arms will cause the rocker to run off the valve tips.
