Thread Tools Search this Thread share on Facebook
  #1
Old 02-17-2009, 04:37 PM
customcabbie customcabbie is offline
352 to a 351
hey im new to the forum and just had a few questions.
I bought my first vehicle back in September, a 1965 ford custom cab pick up
just wanted to switch out the original 352 for a 351 Cleavland. i wanted to know if the motor mounts were the same and if it will hook straight up to the original transmission.if not i have an old c6 in the backyard i can use on the Cleavland. but if i use the Cleavland id like to know if the tranny is compatible with the truck. thanks for your help
Register now (free) or login to remove ads
Old 02-22-2009, 02:59 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi,
The 352 is an FE engine, & uses a different bolt pattern then the 351c, the Cleveland uses ford small block mountings 351W.
FE engines are, 332, 352, 361edsel, 360truck, 390, 406, 410, 427, 427cammer, 428 reg, CJ, & SCJ, I'm not a big fan of these engines, but that in no way means there not good engines, either in stock form or modified, they perform very well.
Rich
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "352 to a 351"
ThreadThread StarterForumRepliesLast Post
parts for 351 windsorDoug RentonEngine509-13-2009 02:18 PM
351 windsor swaped with 351 modifedfordboy210Engine609-02-2008 10:22 PM
Ford 351 Windsor Teardown & Rebuild 101nightrain_rodEngine1007-20-2008 01:57 AM
Ford 352bigdoggcifEngine510-17-2006 05:19 AM
re T-Bird 351 swap.problem solversEngine509-15-2006 04:27 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
