352 Distributor problem...please HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2005, 05:57 PM
tazzman68's Avatar
Justa Freak!
Is there anything lower in the motor that would cause a distributor to get stuck, and not come all the way out? I can get it to lift about a half an inch, but that is all. I don't wanna put to much pressure on it and break something. Any advice will be appreciated.
-ED-
Old 01-28-2005, 06:01 PM
Jmark's Avatar
Ed,,, its not uncommon for distributors to be a real bugger to pull if they have been in for years and years. Goo and junk gets built up on the housing of the dist inside the engine.
When I get a tough one, I spray some carb cleaner around the base and turn it one way, then the next. Lift some, spray some, turn some, spray some, lift some and so on. It will come out eventually. Nothing mechanical inside should be keeping it in.
Old 01-28-2005, 07:20 PM
onebadmerc's Avatar
I need a bucket of arc sparks
You will just have to slowly work it out, twist it slowly back and forth and spray a lubricant at the base. I would also clean all the junk away from the distributor base before doing this, you don't want any dirt or junk getting into the motor. Don't try to pry it out, you will only break the distributor base. I broke mine because I was impatient, it was also a Ford 352 engine, luckily the 390 that replaced the 352 had a distributor in it.
Old 01-28-2005, 07:38 PM
tazzman68's Avatar
Justa Freak!
Thanks for the help
I appreciate it, A little patience, some penetrant, and a little elbo grease and she's out. I'm at a stopping point for the night, and first thing in the morning the intake and heads come off. Thanks again for the super prompt help.
