352 fe stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 05:35 PM
New Member
352 fe stroker
hey guys my plans have changed i am going with a 390 rotating assemblie. my 352 fe block was bored .050 over and i am going to get speed pro pistons, a comp cam with 282 duration and .571 lift should i be worried about piston to valve clearance? does this sound like a good plan?
Old 02-25-2012, 10:56 PM
all of the F E engine have the same deck height and cam to crank locations, you should be fine on your clearance but you should always check on install. However this really isnt a stroker par say. is more of take FE parts out of one block and putting it into another FE block.
Old 02-27-2012, 04:56 PM
As long as what you're talking about is a 390 crank with 390 rods and 390 pistons, it'll all fit. 352 rods have different center to center lengths than the 390 and 390 pistons have a different pin to crown distance and skirt shape. So you can't cross breed 390 and 352 rods and pistons and get it to fit any FE block when attached to a 390 crank.
Bogie
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 12:12 PM
496 Stroker oil pan chasinya Engine 3 08-07-2009 04:49 PM
347 stroker kit old fords Engine 2 02-24-2009 05:54 AM
383 Stroker Ozz1967 Engine 11 11-04-2005 07:08 AM
383 stroker 69camaroboy Engine 2 10-30-2005 12:13 PM
