Thread Tools Search this Thread share on Facebook
  #1
Old 03-06-2009, 01:21 PM
abas_abas abas_abas is offline
355 block... small crack
i have this crack on the passenger side of the block where the starter bolts up too... the crack goes down about 1/8in... i just saw after cleaning the block ill be taking it to the machine shop to get it hot tanked and a hone job so i was wondering if the machine shop could fix this and if not does it really pose a danger as in the starter not being secured properly...
Register now (free) or login to remove ads
Old 03-06-2009, 02:12 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Unfortunately this is a common problem. Most of the time it's because the rear starter brace has been removed & or the wrong mounting bolts are used that don't have the knurled shank. The crack isn't easy to fix either. I seen people weld studs in, weld the block and the easier fix is to use a long stud or bolt that will reach all the way thru with a nut on top. The top isn't flat tho' so a bevel nut was used, may have been in a post by (OldBogie). There was a link to the type of nut needed. Try doing a search for (starter crack) (mount crack) etc...
Old 03-06-2009, 05:51 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
The secret to fixing the problem is Silicon Bronze. I have repaired these type cracks and even blocks with the entire ear gone.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "355 block... small crack"
ThreadThread StarterForumRepliesLast Post
big block or small block chevy69YENKONOVAEngine8105-13-2010 07:26 AM
how strong is a 350 small blockChevyVanEngine1801-04-2007 11:27 PM
400 small block idling problems19nova72Engine1504-16-2006 02:53 PM
Small Block Vs. Big Blockbfrett123Engine310-14-2004 05:27 PM
big block or small block ford?stangfiendEngine312-10-2002 09:55 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
