355 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2007, 08:26 AM
355 build
Im buildin a 355 for my LeSabre Limited Coupe. Im thinkin about just gettin a rebuild kit off of northernautoparts.com that comes with a bigger cam and some other stuff that i cant remember off the top of my head and im plannin on putin some heads on it off of a 305(open for suggestions on heads). What do you guys think i should do? I want to make this car quick. Becauase not many people expect a 1980 Buick LeSabre to come up and challenge you to a drag and kick some a**.
Old 08-28-2007, 10:26 AM
383silverado's Avatar
don't use the 305 heads. they will just bump up the compression and they won't breath very well. if you want a decent priced performance head look into the rhs vortec's . and bump the cr up with the right pistons.( flat tops, or domed. )
http://www.racingheadservice.com/Inf...rtec-Heads.asp
Old 08-28-2007, 12:04 PM
DoubleVision's Avatar
Another thing to be aware of is the pistons that come with the kit are usually destroked pistons, meaning they have .020 off the compression height, while the factory height is 1.560 on a 350, the destroked piston is 1.540. This kills quench, compression and power because it lowers the ratio, and the bigger the overbore, the worse the problem. You will need gears most importantly of all to make that big car quick with any engine. It likely came from the factory with 2.73:1 gears, it`ll need some 3.73`s to have decent street manners. Without gears it`ll still be a slug.
Old 08-28-2007, 02:01 PM
my friend has a 10 bolt rear end with 4.11's in it that i'll prolly end up gettin. but i dont wanna put to low of gears in it cus its my every day car and i do quite a bit of highway driving. I was thinkin 3.73's would be ok or maybe 3.08's. i dunno tho maybe if i get enough power out of it i wont have to worry about gears. i wanna try and make around 400 horse. but i dont wanna use dome top pistons because i wont be able to run race fuel all the time.
Need small block chevy build ideas would like around 500 horse ssmonte Engine 17 08-03-2011 01:25 PM
Help with engine build. Artemis Entreri Engine 16 07-10-2006 03:31 PM
How do I build a 383 stroker? KFXrider88 Engine 2 06-16-2006 12:10 PM
How do I build a 383 stroker? KFXrider88 Engine 1 06-11-2006 07:47 PM
How would you build a 383? A 355? Vortec or package deal? Adrenaline_Fiend Engine 5 04-29-2003 07:58 PM
