350 block bored 0.030" and decked to 9.018". Stack will measure 9.008", piston deck height will be 0.010".
Crank and 5.7 rods of your choice. KB hyper pistons KB197/030. Compression height 1.433".
http://kb-silvolite.com/performance....etails&P_id=94
L31 Vortec heads from Scoggin-Dickey. Modified with 1.250 single springs for 0.525" lift. Part #SD8060A2, $339.95 each. (price may be different by now, quoting out of my 2008 SD catalog). GM 10105117 head gaskets. Rescue a set of low-miles rail rockers from a boneyard, along with the valve covers and intake manifold bolts. '96-'98 Chevy truck with 5700 Vortec motor. Look for sawtooth pattern on the front of the heads.
CompCams hydraulic flat tappet part #12-213-3, grind #292H-10, 292/292, 244/244, 0.501"/0.501", 106/114/110, timing @ 0.006" 40/72/80/32, timing @ 0.050" 12/48/56/8. Installed straight up. Comp's description of this cam:
HYDRAULIC-3000+ Stall in heavy car with 10:1+ compression. BINGO.
1 3/4" long-tube, equal-length headers of your choice, such as Hooker #2116-1HKR, Super Comp. Header, 64–75 Chevelle/Malibu/El Camino/Caballero/Sprint/Wagons, 74 Full Size: 265–400, Full Length Tube 1.75" O.D. x 31", Collector Size 3" O.D., Collector Length 10", Port Shape: Same As Port, Metallic Ceramic Coating.
Professional Products Crosswind Vortec high-rise, dual-plane intake manifold #52028 (satin). $172 on ebay (item 330295109276). 750 carb of your choice. Check out ebay stores such as this for good value on rebuilt carbs....
http://stores.ebay.com/Carburetors-and-More
I have no commercial connection with this store and know nobody there, it's just the first one I came to when I was lookin' for a 750 carb.....
10.3:1 SCR, 8.38:1 DCR, 0.038" squish.
RPM HP TQ
2000 145 382
2500 191 400
3000 241 422
3500 300 450
4000 353 464
4500 403 470
5000 439 461
5500 450 427
6000 421 368
There, a 450/470 motor with iron production heads. Not bad.
