Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 build check up
Old 12-17-2012, 01:04 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Use a new stock OEM GM SBC oil pump.
Distributor: any good distributor with adjustable vacuum advance is fine.
EG: GM style HEI
For this combo: the distributor set up is real simple,
Simply lock out the mechanical advance curve.
dial in the vacuum advance as required. 15deg max limit.
aprox 10+/- deg added at steady part throttle hiway cruise speeds.
use ported vacuum.
