355 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2007, 07:03 PM
355 chevy
i have a 355 highperformance g team highrise intake holley dp forged pistons hydraulic cam&lifters msd 6al ignition, ac yellow short plugs msd wires, sounds like a diesel , builder said it was for racing use 114 octane fuel, is this sound normal, and what can i do make sure its ok to run, dont like sound , with out having to go in motor to change pistons?
Old 07-13-2007, 07:32 PM
DoubleVision's Avatar
Well there are 2 "sounds like a diesel" culprits, one is detonation, which can be caused by carbon build up, too high of spark timing, and too much compression for pump gas use, so if your running pump gas in a high compression engine it`ll detonate itself to death and sound like a diesel doing it, if this is the case then when you hear the diesel show up your signing your engines death wish. Second, Piston slap from the extra clearence honed in for the use of forged pistons. But not many do this practice anymore as most forged pistons today don`t expland as much and can almost be fitted as tightly as cast pistons can. Usually, forged piston slap goes away or gets alot quieter when the engine gets hot. Lastly, Excessive cylinder clearence from excessive honing, or excessive wear. You can slow down the spark timing until the detonation stops, but you can bet by the time you get it low enough to stop detonation, it`ll be so low the car won`t have any power, so either your stuck with changing the heads for heads with larger chambers or a piston change is in order. But if 76cc heads are already used on your engine, a piston change will be in order.
Old 07-14-2007, 05:05 PM
355 chevy
im running msd ignition spark plug gap at 35 , do you think moving it to 45 wound help?
Old 07-14-2007, 06:10 PM
To be honest, no. But you could move up to a colder plug and see if that helps. So your in alex city huh, been there more than a few times.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
t-400 for a 355 CID chevy BLUE82 Transmission - Rearend 3 12-08-2006 10:43 AM
355 chevy blu Engine 2 11-08-2006 07:54 AM
Chevy 355 fireworks show Vander23 Engine 1 04-14-2003 09:09 PM
Buildinging 355 chevy 70 nova Engine 8 04-10-2003 08:07 AM
