Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 chevy hp estimate
Old 06-09-2009, 04:04 PM
my87Z's Avatar
my87Z my87Z is offline
Veteran/Firefighter-Paramedic
well you said that you replaced the head gasket, are the heads still off, if so you can check the volume of the combustion chambers, can you see the part# or s/n# this should also tell you (this would be the best way) that would be a very important thing to know
about you cam, i tried to look up who might make it, and i cant find it (that doesn't mean much) i was trying to figure out the LSA/CL, 230 @ 050 on a 292 cam is a little low, but its not bad, on a 350 is should sound pretty nice, if you have th 67cc heads it's possible to have 380-390hp but i wouldn't expect much more than that (and that is tuned well) but if its the 76cc heads i would guess a bit lower
