355 flat top chev - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2010, 11:58 PM
355 flat top chev
i have a 355 chev smallblock kb flat top pistons with eagle 6 in rods 10.3.1 compression 64cc 462 camel humps 2.02/1.60 valves a hydraulic 292h .501/.501 244/244 cam 106 lobe seperation and a msd distributer with a dominater 750,my question is how much torque and horse power will it make? any one run this combo?
Old 04-14-2010, 05:57 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Im getting about 426hp@6000 and 425ft/lbs@4500. this is with a high flow single plane and large tube headers going into mufflers.
Old 04-16-2010, 04:11 AM
ya thank you. im racing oval track 3/8 mile tight corner usually! im tryn to get out of the corners faster i have moderate to good suspspension and was just wondering why most the guys i race against have about .533 and 250 duration solid cams? dont get me wrong i do well but are they really picking the better way to go? i feel safer with hydrolic ehat would you guys do? should i go bigger?
Old 04-16-2010, 06:18 AM
How fast is fast enough?
hydraulic isn't any safer, just easier. Your combo may not be wrong, then again it may not be optimal. Depends a lot on the driver, the engine, the car, and the track. If you need more up top a bigger cam may be the way to go- for best results consult a cam grinder.
Old 04-16-2010, 06:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If solid cams are allowed, it's a pretty safe guess that the optimum set up will include one. But the whole package- including the gearing and suspension has to be dialed in for it. A car set up to run w/375 HP @ 5500 RPM won't handle the same w/450 HP @ 6800 RPM, for instance.
The forward bite and cornering traction/balance is going to play a huge part in whatever you do. There are whole books (many of them) dedicated just to chassis dynamics, and it is one of the MAJOR- if not THE major factor- in a winning combination.
Could you give us a brief run-down of the rules?
Old 04-16-2010, 09:49 AM
F-BIRD'88's Avatar
Yada Yada Yada
If you want to come out of the corners harder, degree the cam and advance the cam to a 102-104 intake c/L.. Lock out the distributor advance curve and set the locked timing at 34-36deg BTDC. Find True TDC with a piston stop first and then correct the timing tab./balancer.
put a steeper gear in the car.
There is nothing "safer" about a hyd cam. A solid lifter cam will make more power and rpm higher allowing you to accelerate faster. you can run a steeper gear too.
Most circle track cams are 106LSA and go in advanced on a 100-105 intake C/L to maximize off the corner acceleration.
try this one: http://cranecams.com/?show=browsePar...tType=camshaft
very strong powr off the corners
or this one:
http://iskycams.com/timingchart.php?..._number=201CC1
more power than the 292H more rpm. likes to rev. put some gear in it.
Old 04-16-2010, 01:25 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Are they drivin' around you?
Ford 400 Dished to Flat Top Pistons = Rebalance Crank? My79Ford400ciF1504x4 Engine 9 03-22-2010 08:28 PM
big block mopar, zero deck, flat top pistons, & open chamber heads? 406 ss monte Engine 9 02-01-2010 01:47 PM
350 Flat top pistons question DENCOUCH Engine 2 05-27-2008 09:22 PM
Where to find 351m flat top pistons? kane583 Engine 4 07-24-2006 01:17 AM
