355 Misfire when accelerated
Hey guys I got a 355 with 400hp a slight misfire when I accelerate it. I accelerate it and it misfires, then it continues to rev up just fine. Idles fine
Could this be fuel pressure? Fuel pump or any other ideas? Carb? Thanks, JD |
Agree with checking that^^.
Is it a in-cylinder misfire, or a "cough" into the intake when floored?? What is you initial and total timing?? What carb?? More info you give, easier it is to narrow down what to look for.
To add to what the above poster mentioned, if they are carbon core wires, they are probably junk, get some spiral cores, and take a good look at the coil and rotor. A bad wire can over work the coil and burn a hole through the rotor.
Pretty much all the later model tuneups I do include a new coil unless they are COP, and an upgrade there is not a bad idea.
I don't know how old they are but I'll change them out and see how she responds.
I'll post back as soon as I replace those cables. Thanks, JD |
I put a new set of Procomp 10.2's on my 350 a week ago, and I swear it runs better. Even the exhaust sounds different. There's no telling how old the stock 8.5's were, they came with the engine I pulled from a 79 chevy.
I just went through this on my 350. I had replaced..rockers..push rods..lifters..a new Air Gap. Buttoned it back together and now had that miss.
Thinking I set my valves too tight I reset them..still same..re-did them still same. Idle fine..the under load miss until 2500..then run/rev excellent. A good friend..75 years old..asked me.. "If I brought my car to you with the same miss-fire..and you knew nothing about my motor history..what would you think it was..?" I would think electrics..and so it was. Taylor wires..were carbonized under heat shield. Not shorting to header but not getting adequate spark. Bought some good wire..made my plug wires..runs perfect. I'd look at those wires..or even a cracked ceramic on a plug.. |
| Narrowing down on unusual misfire, but still need help | Argess | Engine | 11 | 07-24-2010 02:27 PM |
| Very random misfire....hardly ever happens, but.... | Argess | Engine | 7 | 07-17-2010 08:59 PM |
| AFR dyno comparison on their 355 vs my 355 | black66 | Engine | 21 | 10-13-2009 04:57 AM |
| false OBD 2 misfire reading??? | briansansone | Electrical | 16 | 01-01-2009 07:23 PM |
| Idle misfire ????? | motoxracer | Electrical | 5 | 03-13-2006 05:49 AM |
