355 motor build - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2004, 09:10 PM
355 motor build
Hi my names mario and im new to the board. I drive a 69 camaro ss .
-Engine - 355 - fullie heads, small aftermarket crane cam. specs unknown. , street dominator single plane manifold, edelbrock 650 carb
Transmision- turbo 350 , stall 3000
411 gears - 12 bolt rearend
Im looking to build up my motor to run 11's .
Any good combos u guys know of?
Replacing - heads, cam , intake , and carb.
Already have a Nitrous plate kit 150 shot
Any suggestions?
Old 01-28-2004, 11:30 PM
68Impala's Avatar
welcome to the S.B.
you probably wont need nawwwssss to get your car down in 11s
Since you run a single plane, you're good there - and the carb is perfect... I would get a good dual exhaust hooked up, tho.
For heads, I have heard (and i could be wrong here) that both Dart and World Industries makes some really decent flowing heads, or you could even have your machine shop take a go at them (clean, port, polish, new hardware, 3 angle valve grind, etc, etc)
What's your compression? If its guts are stock, you can upgrade to some domed pistons, kick up the compression a little, and heck, even toss in new rods and bearings while you're at it.
And, definitely match the cam to your heads - I dont know what Dart would suggest, but something around 302/302 would probably kick some *****.
I am just guessing here, feel free to set me inline (engine veterans)
68
Old 01-28-2004, 11:49 PM
lluciano77's Avatar
Short changed on common sense
Put your money into the heads. I would get at least a 200 cc intake port. You will want at least 9.5-11:1 compression.
Old 01-29-2004, 08:24 AM
or could you could run a low compression engine like 8-8.5 and then throw a supercharger on it after you have built it up! thats what i'm planning on doing to my pontiac 400 some day! but here is just a different idea for ya, and then you get that cool whistling sound lol
Old 01-29-2004, 09:05 AM
Which end of the 11's, 11.00's or 11.90's?
Chris
Old 01-29-2004, 10:41 AM
firestone's Avatar
http://teamrfc.gospelcom.net
AFR 195cc heads, Comp XE284h cam, 1.6 roller rockers, 750 carb, Performer RPM air gap intake. This alone will put you close if not into the 11's. With a 150 shot, you would be looking at low11's.
Adam
Old 01-29-2004, 04:46 PM
dont go with nitrous, i cant stand when i see nitrous used! that is basically saying that you cant build your motor to the power that you want!
Old 01-29-2004, 06:24 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
[QUOTE]Originally posted by Cstraub
[B]Which end of the 11's, 11.00's or 11.90's?
Good point. When you hit 11's, low and hi are a far jump in performance.
I cant agree. Ive never really believed that you can count one power adder as a cheating device, but not another.
To me theres no difference in building a motor for nitrous use than there is in building one for a supercharger, or dual 4's. You get power however you like it. At the end of a race its who gets there first, however you get there first. HG
Old 01-29-2004, 07:21 PM
i get what your sayin, but i have just never liked spraying something into your motor. and since all a supercharger does is force the air into the motor at a faster pace, then you cant really consider it like nitrous! but i guess they are kinda alike
Old 01-29-2004, 07:39 PM
I used to kinda think the same thing, but kinda realized that any power adder is a power adder. I guess its just whats your likes. LOL HG
Old 01-30-2004, 05:11 PM
my cars got trw forged flat top pistons and flowmaster exaust with 2 in headers..
Old 02-01-2004, 12:55 PM
Tazz
nitrous oxide?
I plan to stash a 100 shot of Nitrous in the trunk just in case I want to have a couple of laughs and giggles?? LOL LOL
Tazz
Rat Rods Rule!
Old 06-23-2009, 04:22 PM
power adders
you know the old saying nitrous is nice but id rather be blown...hehe..but theyre simply different ways of getting more oxygen into the motor. nitrous has the stigma maybe cause its new school. personally, i cant see why youd want a machine [blower] to do the job nitrous can do. of course you have to have super duty fuel,ignition, and piston systems on board before you consider either.have fun
Old 06-24-2009, 02:05 AM
327NUT's Avatar
Hey Urban......see you're new, ALWAYS look at the date of the thread first, this one is over 5 yrs. old.......info only.
Old 06-24-2009, 02:36 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Thanks for the heads-up on the date 327NUT. Since the thread is about info, in a 3400 lb Camaro, it will take 400 hp to go high 11's and 500 hp to go low 11's, assuming the rest of the drive train and suspension are up to the task.
