#1
355 rebuild
I received a 355 in a trade the other day. I'm looking to freshen up the engine and change somethings to make 400hp 450 ft lbs out of Its. I am mainly looking for what cam intake combos will work for the heads I have to make this much power. Its going in a street/ small amount of strip 91 Camaro rs. Running a th350 trans with a 2500 or 3000 stall with a 150 no2 shot
Current spec 4 bolt main block Twc .30 forged pistons GM steel crank GM rods Eldelbrock 6089 heads Comp 1.5 roller rocker Comp cams (don't know the duration or lift but is a solid lift can with an aggressive idle) Eldelbrock rpm air gap Holly 850 do Not really looking to change to a 383 yet any advice would be greatly appreciated Engine was in a drag car when pulled Register now (free) or login to remove ads |
| Thread Tools | Search this Thread |
| Similar Threads for: "355 rebuild" | ||||
| 4L60e, to rebuild or not rebuild, that is the question ? | old yukon | Transmission - Rearend | 31 | 04-07-2011 12:25 PM |
| first 350 rebuild | campracing | Engine | 9 | 09-10-2009 04:34 PM |
| 350 Rebuild!!!!!!!!!!!! | MyMalibu | Hotrodding Basics | 24 | 08-20-2006 10:26 PM |
| To rebuild or not to rebuild - Engine (and Tranny) | KristensRanchero | Engine | 13 | 09-07-2004 01:20 AM |
| Tear down 1st rebuild and rebuild again help.... | HemmiGremmie | Engine | 10 | 08-20-2002 10:29 AM |
