355 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2009, 12:34 PM
pena0724's Avatar
355 sbc
Hey guys i just finished my first rebuild on a sbc 350 and am not getting the kick i want from the start this is what i have going in my 87 olds cutlass supreme 350 turbo stock 7.5 rearend
350 bored and honed .30 over
lower end balanced
flat top hypernuaetic pistons
Alum dart pro 1 heads 180 runners 64cc 2.02 intake 1.60 exh
victor jr intake
4150 Holley 650cfm double pumper
3 inch headers converted down to 2.5in true duel exhaust droped before axel
comp cam here are the specs. http://www.compcams.com/Technical/Se...umber=12-246-3
huges 2,500 stall
summit HEI setup cd box, distributor, coil and wires.
any suggestions?
Old 06-08-2009, 12:51 PM
What do you mean by now getting enough "kick"?
Based on your CID and 180cc Dart heads, my thinking your cam has too much duration. A 230/236 is best in a 383 or larger CID engine. What that does is move the power band too high in the band and without a lot of rear end gear the engine will feel soft down low.
Jake
West Point ROCKS!
Old 06-08-2009, 01:03 PM
How fast is fast enough?
That cam is a little big for a stock rear gear, but not too terrible. You can move up a little on the gear later after your rear end explodes. I'd go with a RPM intake over the Vic Jr. though, the Vic Jr either needs more cubes, or more gear to make it shine. Be sure to check quench distance- it'll have a big effect on power and tuning.
Old 06-08-2009, 03:55 PM
ericnova72's Avatar
More for Less Racer
These cars typically have 2.41, 2.56, or 2.73 gears. Change them to something 3.42 or better and you will be a lot happier with the off-the-line performance.
Freshly Rebuilt sbc 355 cranks over hard awoodman Engine 8 02-09-2009 06:52 PM
355 SBC heads zildjian4life218 Engine 6 12-08-2008 11:54 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
What is a 355 SBC? frankenvette Engine 11 09-12-2004 07:59 AM
