Thread Tools Search this Thread share on Facebook
  #1
Old 02-22-2010, 05:34 PM
blackchevy3de blackchevy3de is offline
355 sbc
what makes a 350 sbc a 355 is it more then bore
Register now (free) or login to remove ads
Old 02-22-2010, 05:45 PM
chlsnk's Avatar
chlsnk chlsnk is offline
"Love what you do for a living
Nope just .030 over bored.
Old 02-22-2010, 08:37 PM
t-tung t-tung is offline
May be a dumb question but when you bore it .030", can you get away with using stock pistons and larger rings or do you have to use larger pistons as well? The reason I ask is the truck I bought has a 350 bored .030" over and i had a friend of a friend tell me the guy might have gone this route. Just trying to figure out what I'm working with without tearing it down.
Old 02-23-2010, 01:58 PM
030 over 350
ive heard of guys doing that ,boring 030 over and using standed bore pistons , with over rings , i wouldnt do that .
Old 02-23-2010, 02:03 PM
ap72 ap72 is online now
How fast is fast enough?
if you bore it .030" over then you use .030" over pistons... Its not rocket surgery.
Old 02-23-2010, 04:18 PM
It seemed pretty obvious to me too until somebody mentioned otherwise. Say they did just use over rings, what might be some tell-tale symptoms? Low, compression, burning oil, etc???
Old 02-23-2010, 04:31 PM
my87Z's Avatar
my87Z my87Z is offline
Veteran/Firefighter-EMT-I CRT
a bunch on piston slap
Old 02-23-2010, 05:04 PM
Slap... .005 can cause slap. This would be piston sacking you in the face with brass knuckles.
Old 02-23-2010, 05:27 PM
my87Z's Avatar
hahaha, X2, i agree i was being a little sarcastic
Old 02-23-2010, 05:41 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
If it`s bored .030 and a standard piston was used it wouldn`t have enough compression to run. If it did the amount of slap on the bores would break the piston skirts in a hurry, and the excessive piston rock from such a loose fit would likely cause the piston to kiss the head. I love it when guys talk smack like this. We can prolly add him to the list of "350 rocket" and "3/4 cam"
Old 02-23-2010, 06:34 PM
add who to the list? And who was "talking smack"? I asked a legitimate question to get some clarification because it didn't sound right to me. I'm by no means an engine guru. Thanks for the info.
Old 02-24-2010, 08:20 AM
my87Z's Avatar
they are not talking about you, they are talking about the friend who said that he may have done that, or about some people who say you can do it. no one is attacking you bud, you did ask a legitimate question and you got a legitimate answer
Old 02-24-2010, 08:41 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Great answer!
Seriously to the OP and t-tung: Any time the cylinder is bored a out to a larger diameter, the piston will need to be exchanged for the appropriate size. i.e. .030 over bore diameter will need .030 oversize pistons.
If the cylinder is only honed out a maximum of a few thousands of an inch from the original bore diameter, then the original pistons can usually be used with new rings. Oftentimes, if it takes more than .005 inch to "clean up" the bore, it is adviseable to have the cylinder(s) bored out and oversize piston(s) installed.
To put these dimensions in perspective, the diameter of one hair on your head is approximately .003 inch.
Old 02-24-2010, 08:46 AM
Thanks Frisco.
MY87Z- after I reread it a few times I see who he was talking about. thanks for the help.
Old 01-25-2012, 04:10 PM
Subaru and Chevy? Subaru and Chevy? is offline
response to forum
great posts guys. i was researching this exact question and found myself here on accident. had to join the site but....right on guys. 79 chevy with a 350/355 thanks again
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "355 sbc"
ThreadThread StarterForumRepliesLast Post
building a 355 SBCCodyC10KidEngine012-27-2009 07:41 PM
Freshly Rebuilt sbc 355 cranks over hardawoodmanEngine802-09-2009 06:52 PM
355 SBC headszildjian4life218Engine612-08-2008 11:54 PM
Late model 350 SBC QuestionSmoker113Engine302-19-2005 10:12 PM
What is a 355 SBC?frankenvetteEngine1109-12-2004 07:59 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
