355 sbc 556 hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2013, 03:45 AM
355 sbc 556 hp
ive got a 355 sbc 2bolt main chevy steel crank scat pro comp 6inch rods 11.5-1 comp .640 lift isky solid roller crane ultra pro lifters crane rev kit jesel rocker shaft 1.6 in. 1.5 ex. older afr210 heads teamg intake 950 pro systems carb makes 556 hp and 488 torque i want to upgrade to the new 210 comp port afrs and their new titan composite intake i want hit 600hp with the upgrade and 500 torque which id run on 94 octane at 39 degrees total. i think with the new afrs which flow 322@.650 my old afrs flowed 286@.600lift will have to see what the dyno says what do you think......... :thum bup:
Old 02-26-2013, 11:50 AM
vinniekq2's Avatar
If the 210s flow 322? my 227s with porting flow 327, then your 355 has the potential to make the power. I guess that your engine is turning 8,000 rpm?
When you talk about 260 plus duration @ .050,thats not a super non race camshaft.
Old 02-26-2013, 12:01 PM
im talking about the new afr comp ported 210s not the race ready version they flow311@.650 lift and i do shift my engine at 7700 and its been revved to 8800 and im running a 2 bolt main that isnt balanced either:e vil:
Old 02-26-2013, 12:03 PM
hey vinnie where abouts in b.c. are ya from im from port alberni brother.
Old 02-26-2013, 12:13 PM
vinniekq2's Avatar
Im on the mainland. Port coquitlam.
I was just doing the math with the numbers you provided.
I have not researched the AFRs ,sounds like extremely good flow numbers.
They also cast 245s now
Old 02-26-2013, 12:31 PM
Faith - Respect - Trust
Your Forum name gave it away that you where from Canada. I was reading the posts and sure enough, Port Alberni. I lived in Victoria in the late 70's and early 80's. Sounds like a great car...at those RPM's, not balanced and a 2 bolt main, aren't you kinda gritting your teeth and driving with one eye half shut...LOL...what are you running for suspension and rear end?
Ray
Old 02-26-2013, 12:36 PM
running leafs with caltracs 4.88 12 bolt moroso brute strength diff moser axles still runnin drum brakes all around
Old 02-26-2013, 01:01 PM
vinniekq2's Avatar
I had a 65 Acadian. and 3 chevy IIs.I had a 65 Beaumont too,eh?proud to be from C eh N eh D eh
Old 02-26-2013, 01:08 PM
As I was telling Vinnie, I'm here to learn about suspension, engine building and so on...I just looked up Caltracs on the net...boy they've come a long way from the slapper bars we used to build in the 60's and 70's.
Ray
Old 02-26-2013, 03:07 PM
hey ray yeah the caltracs work great they run 7sec leaf cars with em.
Old 02-26-2013, 03:09 PM
hey vinnie do you run anything at mission.
Old 02-26-2013, 03:20 PM
vinniekq2's Avatar
new mission
My vette is a road race,parking lot pylon dodger. Last time I ran mission was my 1980 Z-28 BB. Had words with mister Farmer.
Maybe after the car is painted I can make a few runs,it wont hook with street tires and Im not sure I want to run slicks with 3.50 gears
Old 02-26-2013, 05:01 PM
That's incredible...how things have improved over the years.
355 sbc GM/Jeep Engine 1 08-29-2012 02:11 PM
355 sbc blackchevy3de Engine 14 01-25-2012 05:10 PM
sbc 355 stepj19 Engine 6 07-02-2009 09:26 PM
355 sbc pena0724 Engine 3 06-08-2009 04:55 PM
What is a 355 SBC? frankenvette Engine 11 09-12-2004 08:59 AM
