355 sbc compression question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2010, 03:17 AM
Tommy Brown's Avatar
355 Chevy Boy
I have some afr heads that are 69cc with 2 different set of dome piston, one set of pistons is 11, the other set of pistons is 12, my block is 0 deck can anyone tell me what type of compression the two would make out to be bacause i dont know how to add that up proper. Thank you for any help that you may have.
Old 04-23-2010, 04:05 AM
ericnova72's Avatar
More for Less Racer
I use the calculator at www.wallaceracing.com , scroll down the page and click on automotive calculators, you will need a gasket thickness to get an accurate result.
-11cc(dome) was 11.9 to 1, -12cc(dome volume) was 12.1 to 1, both figured with an .041 gasket thickness and zero deck.
Old 04-23-2010, 08:33 AM
what is the cc of the piston.
when pistons are rated as 10;1 or 11:1, there is a head combustion size that goes along with that rating. typically they use a zero deck and 64cc for a sbc.
So, do you have any more information about the pistons? a part number would help a lot.
Old 04-23-2010, 11:10 AM
355 Chevy Boy
no i dont have any more info on the piston i really dont remember which one i use when i built the motor all i remember was 11.1 an 12.1 dome piston
Old 04-23-2010, 03:48 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
then sorry but unless you're willing to take the heads off and cc the top of the pistons then we really can't help you that much. to be honest between what the manufacturer says it will be and what it actually ends up being at the end of the day when everything is togehter and with all the different part used they can be off as much as 0.5 of a point and sometimes more
Old 04-23-2010, 07:56 PM
ericnova72's Avatar
More for Less Racer
My previous reply won't help you, I took the info you gave as being the dome volumes. If all you know is that they are 11-1 and 12-1 pistons you will be unable to find out the true compression ratio you have without knowing or measuring the dome volumes.
Old 04-23-2010, 08:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IF the 12:1 pistons were with a 64 cc chamber, a zero deck and a 0.041 composite gasket, the CR w/69cc heads will be ~11.22:1.
With the 11:1 pistons, the 69cc CR will be ~10.34:1.
Old 04-26-2010, 11:35 AM
355 Chevy Boy
I just found out that they is 12-1 with 64cc heads so that would make it 11 something with the 69cc heads.
Old 04-26-2010, 12:03 PM
my87Z's Avatar
more than likely yes, but there is no absolute way to tell without pulling the heads off and really finding out what pistons you have in there, getting either the part numbers or measuring the volume of the either dome, dish or valve reliefs
Old 04-26-2010, 12:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ya think?? lol
Old 04-26-2010, 12:30 PM
355 Chevy Boy
No think you cobalt327 an the rest of you guys thats on here for all of your help
Old 04-26-2010, 12:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm just yanking your chain- and anyway, it is always good to have verification.
Good luck.
Old 04-26-2010, 12:38 PM
my87Z's Avatar
dont get mad at cobalt, he just gets a little cranky sometimes like the rest of us, if you look at one of his earlier post he stated exactly what you did, i think that might have been the source of his frustration
Old 04-26-2010, 12:43 PM
355 Chevy Boy
It's cool i just did what my87z said to do an i called the guy who build it an he told me what they were.
Old 04-26-2010, 01:05 PM
my87Z's Avatar
good stuff, anymore questions
cam and compression question Jamie Thomas Engine 16 04-14-2008 09:19 PM
2 part question compression and est HP chopperdave70 Engine 3 02-27-2008 10:47 PM
compression question neverfastenuff Engine 4 11-11-2007 12:37 PM
compression ratio on blown sbc? Marcus Engine 2 09-19-2003 02:09 PM
compression physics question WayOutCat Engine 13 08-12-2002 05:05 PM
