#1
355 sbc engine dyno...???
hi right now i have an 1984 chevy c10 full weight am building a 355 for it i was wondering like how much hp or quarter mile time it will have any guesses...???
355 sbc 2bolt main, edelbrock performer rpm vortec intake, edelbrock 600cfm carb L31 vortec heads, flat top pistons, double roller timing chain, 1.5 roller rockers, 280h comp cam, 1 inch carb spacer... TRANSMISSION UPGRADES: TH-350 fully customized with a 3,200+ stall torque converter, blue clutch pack, trans go shift kit, servo...and rear end with 3.73's what would be my et??? and engines hp or torque numbers???any guess??? Register now (free) or login to remove ads |
#2
Don't know where the guy w/the dyno simulator has been lately- I'd like to have read his take on R/A that was going on until recently. Where you at, TI?
#3
I have an 86 c-10swb with a 355. I havent ran it dwn the track but it'll git it.
As for as hp im right at 290hp. I had to go back to stock heads because my custom ported heads went bad so now im looking into getting vortecs |
#4
so mid 13 run??? i did a comp cams camquest dyno and it came off with 462hp @ 6000 with 455 @ 5000 peak torque... using L31 vortec heads and large tube headers mufflers without cat, 9.5 compression, 280h comp cam, and in a 350 bore not in a 355 bore... would 462hp be possible for my setup??? its cuz i want to run like a mid 12 with this 84 c10 short bed truck... |
#5
The Comp deal sounds a little optimistic to me. But I'm putting together a Vortec head engine in the near future, so I hope you're right! |
#6
whats a WAG??? well i hope the camquest is right lol
| Thread Tools | Search this Thread |
| Similar Threads for: "355 sbc engine dyno...???" | ||||
| 350 SBC marine engine sluggish? | daeble | Engine | 17 | 02-21-2010 05:26 AM |
| 1968-1969 olds 455 engine is this good and how can i id | 1968olds455HO | Engine | 5 | 09-02-2009 11:53 AM |
| SF oil???? | n-gin | Engine | 6 | 07-09-2008 01:37 PM |
| 355 blower engine, two 850's or 750's | deno | Engine | 11 | 01-01-2006 03:41 PM |
