Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 sbc first start issues
Old 02-09-2013, 12:08 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Since it started and ran, I assume you're close on timing, you couldn't adjust out the backfiring turning the dist a small amount to get it timed?
Is the cam hyd or solid? If you're wires are in the right place, I'll go with your valve adjustment is off, too tight.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
ghaddon (02-09-2013)
