Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 sbc first start issues
Old 02-09-2013, 12:51 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Use the IC EC method + the up down pushrod method to set the preload on the rockers.
the spin method results in exccesive tight preload- lifter bottoming.
A big cam will need a modified timing curve or locked out timing as it needs a ton of initial timing
a stock distributor timing curve will not work with a racey cam.
what are the cam duration specs.
A final rocker preload set up will need to be done with the engine fully warmed up and idling.
loosen each rocker and retighten each 1/2 turn preload from 0 lash.
