Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 sbc first start issues
Old 02-09-2013, 01:23 PM
ghaddon ghaddon is offline
Ok thanks for those suggestions.
If I remember right duration is 263 @.050
Ill reset valve lash using the updown method for the pushrod. Sounds like a few of mine were to tight causing my restart issue. Ill reset the timing and also double check plug wire setup and give it another go in the morning
