355 sbc first start issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2013, 12:53 PM
Just rebuilt my sbc
4 bolt block
10:1 compression
64cc heads
190cc intake runners
.500 cam (custom spec from Crower) flat tappet
holley 1850-5 carb (supposedly new but no proof)
fuel is 25% vp110 leaded 75% 91 pump gas
ran electric fuel pump to prime carb, set at 7.5psi
motor started right up and brought up to 2000rpm for cam break in, lots of backfire and poor throttle respose to varry rpm, engine died when i barely slipped on the throttle with my finger. Didn't want to restart but also I didnt want to crank forever and kill my new cam... 12v to dist is good. Thought it was a fuel issue so ran the pump and got it to stay steady pressure running fuel into a gas can. It wasn't running well enough for me to check timing but here is how i set it up on the engine stand. Set timing pointer at 8BTDC and ran pointer right at cyl number one and gave it a slight turn of advance. Should be 10 or 12 i would guess. Am i wrong in my method?
I have also been told that this carb is bad for a low vacuum large cam motor. I am running no vacuum advance on the dist. the tranny is a very very built th400 with a full manual valve body. Point being there are no vacuum lines used in the build. What is my next step? I need to get this cam and lifter set broke in properly, is it possible i set up with valve lash to tight and now that it has run it is acting like it has tight valves? my motor experience is with 250f motocross engines. I have built numerous 40+hp 250cc bikes I raced but this is my first experience with a v8.
thanks for the help! This site has been a huge help in my build
Old 02-09-2013, 01:08 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Since it started and ran, I assume you're close on timing, you couldn't adjust out the backfiring turning the dist a small amount to get it timed?
Is the cam hyd or solid? If you're wires are in the right place, I'll go with your valve adjustment is off, too tight.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
ghaddon (02-09-2013)
Old 02-09-2013, 01:17 PM
thanks,
yea its a hyd cam,
here is what i just found before I leave shop for the afternoon till tomorrow morning. Pulled the driver side valve cover off and cyl 1 ex is down so decided to reset lash on the intake on cyl 1. spun pushrod then went to put on half turn, felt hard, well it was because it was compressing the valvespring. this means the lifter is bottomed in the bore correct? If so how do i proceed from here. I plan on resetting every valve before i go for a restart.
Old 02-09-2013, 01:20 PM
64nailhead's Avatar
Check the basics - all plugs wires on correct cylinders. Were you checking the timing during breakin? I do this everytime since I did my first build because you will know immediately what is going on with the timing. For example, how far is it advancing, is the timing consistent at a consistent rpm, and is the light coming on at every revolution?
If your timing is correct (or close) I would guess you have a severe lean or severe rich condition based on a touch of the throttle stalled the engine. This is assuming that carb is operating properly. Did you smell gas in the exhaust when it was running, like a severe rich conditon, the smell would be obvious.
Personally, I would restart it with the timing light and see what's happenning, also be ready to check your float heights with it running (how did you set them before starting). I wouldn't be to worried about the cam if you lubed it properly.
I've been right where you are the 1st time I built a motor. I didn't use the timing light and it took me a day and half to discover that my Cloyes timing set was marked incorrectly on the cam gear. Alot of disappointment was felt until I figured it out. Since then, using a timing light while someone else cranks it over allows me to verify that everything is fine immediately when the cranking starts, or I know before it ever starts that the timing is out of whack and I need to find the cause.
Just my opinion for what it's worth and bear in mind I don't claim to be an expert.
Keep your head up and recheck the basics and then give it another whack.
Old 02-09-2013, 02:23 PM
Ok thanks for those suggestions.
If I remember right duration is 263 @.050
Ill reset valve lash using the updown method for the pushrod. Sounds like a few of mine were to tight causing my restart issue. Ill reset the timing and also double check plug wire setup and give it another go in the morning
Old 02-09-2013, 03:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
IMO you'll be lucky if it cranks locked at 36* initial, especially when warm.
Semper Fi
Old 02-09-2013, 07:34 PM
Def typo on the duration! Its 234@.050 lol. Much easier spec to work with I think...
Old 02-10-2013, 03:48 PM
thanks to all of you for the helpful answers! she runs great now. super happy with the results of some carb changes. more timing, and resetting the valve lash. fired right up and got 15min of cam break in before temps got high.
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 12:30 PM
Newbie with 355 issues. Please no flames coolhandsr Engine 6 04-28-2012 10:15 PM
Lots of issues. Not sure where to start (or if I should start...) oldsevenfire Modern Electronic Engines 18 03-24-2012 02:56 PM
circle track 355 fuel issues. BigRoy1978 Engine 11 07-23-2010 11:52 PM
355 won't start chevythmpr Engine 19 12-11-2009 12:07 PM
