Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 sbc timing help
Old 12-11-2009, 11:37 PM
6sally6 6sally6 is offline
Assuming you have it running......this is what I would do. Get a timing tape and a set of light weight springs for Summit or maybe your local auto parts store. Attach the tape to the harmonic balancer as per instructions, with the TDC on the tape to match the TDC markings on the balancer. Install the light springs in the distrib. Using your timing light, with the vacuum advance plugged, bring the RPM up to about2000-2500rpm. Turn the distrib until the pointer is on 32 degrees on the tape. Tighten the distrib down and plug in the vac. advance. Go for a test drive. If no spark knock move the distrib. up until its 34/36 at same RPM. Try that. See if it cranks over ez or does it drag. Play with it until it feels like you like it and does not spark knock(rattle) under load. Re adjust carb after timing is right. I would guess about 10/12 degrees initial advance with full advance of 34/36 @2500RPM. Yours maybe a little more or less.
6sally6
