Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 SBC Tuning help
Old 11-27-2011, 11:10 AM
oldblue1968chevy oldblue1968chevy is offline
my stock fuel pump was putting out 10psi, edelbrocks like around 5-6psi. I installed a regulator and limited the fuel pressure to 5.5psi, really helped the idle.
Thumpr cams suck (i have the small one).
I limited my vac can to 10* with a small drill bit and installed the 375/41 weights in the distributor
