Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 SBC, would like Hp and TQ estimations.
Old 01-27-2013, 12:01 PM
Joel78Vette Joel78Vette is offline
I have a SBC 2 bolt-350 bored .030" over with 062 vortec heads (now 175cc intake runners and 60.2cc chambers) with stock valves (yes 3 angled), after-market springs (1.265" singles) set at 122#'s, 7/16" studs with guide plates; cast steel crankshaft, eagle rods, flat top, 4 valve relief, hyper-eutectic pistons; polished professional products cyclone intake (dual plane good to 5500 rpm's) topped off with a stock 650 thunder series edelbrock carb. The camshaft is a Howard's Race cam (retro roller)-214/218@.050", .488/.495" lift w stainless steel 1.6 full roller rockers. Quench is about .057". about .016" in the hole with a .041" gasket (1003, I believe). Static compression sits about 10:1 at 1700 ft above sea level. I have a full 2 1/4" hooker exhaust with 1 5/8" - 3" ceramic coated headers. A level 2 700r4 w 2200 stall converter and 3.55 rear gears on 27" tires (255/60r15). The block mains have been aligned honed and have studs vs. bolts. Good Hp and TQ numbers would be appreciated. Thanks, Joel
