Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 SBC, would like Hp and TQ estimations.
Old 01-27-2013, 05:52 PM
Joel78Vette Joel78Vette is offline
Originally Posted by techinspector1 View Post
I'm seeing your static compression ratio at closer to 10.6:1 and would counsel you that the cam is too short and the squish is too wide.
Sir, can you explain also what you mean by the squish being too wide? Is there some rules about the squish in conjunction w/static compression?
I understand that the compression may be too high for that cam, but I couldn't afford the .051" thick gaskets at the time to bring me down where I felt more comfortable either. I know it sounds absurd to do all of the work I did for the sake of $60 or so and then not have the optimum motor that we all hope to build and enjoy.
