355 SBC, would like Hp and TQ estimations. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-27-2013, 09:54 PM
And i believe, with your current cam, and the 63cc heads and 0.015 gasket your still at 8.9dcr which is likely still to high for pump....the good quench will help, and depending on what fuel you have access to......maybe.....but not the safest choice.
  #17 (permalink)
Old 01-27-2013, 10:04 PM
And last but not least, another very good read
Dynamic CR
The Following User Says Thank You to bygddy For This Useful Post:
Joel78Vette (01-30-2013)
  #18 (permalink)
Old 01-27-2013, 10:07 PM
I stated 63cc because they were very mildly "cleaned" up. Originally I know they are 64cc. Just hoping is all.....
  #19 (permalink)
Old 01-27-2013, 11:20 PM
Joel78Vette, What type pistons do you have in this engine? Flattop or dished pistons. Do you know the name brand or part number, or piston head volume? The cylinder head chambers are 60.2 ccs on the set of heads on the engine now correct! You also say you have another set with the chamber volume of 63ccs. These measurements need to be checked and correct! Has the deck of the block been milled, also did you measure from the top of the piston at TDC to the deck of the block. You said you have .016 deck clearance. Please post some answers.
  #20 (permalink)
Old 01-30-2013, 03:51 PM
Originally Posted by bygddy View Post
0.025 in the hole, flat tops 4vr we will say 7cc, 0.015 felpro head gasket, PN#1094, your 63cc heads (check and be sure, because they won't actually be 63) but assuming......this gives you 10.3:1 and 0.040 quench.....
You mentioned 0.016 in the hole at the top, then I believe said 0.025 further down? If the block hasn't been decked this is more likely...
I cc'd a chamber on my 2nd set of 062 vortec heads and got 62cc's. Also I am in the hole .016". The .025" is the piston slap or piston to wall distance. I know that has little effect on the overall compression of the motor but just wanted to input all the data when jeepstrokers.com/calculator asked me for it. Also my pistons are H345ncp .030" with 4 valve relief (about 6cc's).
  #21 (permalink)
Old 01-30-2013, 04:04 PM
I have access to 93 fuel. Also, I'm going to work with my total timing more, maybe as low as 29 degrees and run the cooler AR103 spark plugs. If it doesn't fix the pre-det issue then I'm going to run the other higher CC heads along with the shim head gasket AND the 2 step higher cam with the IVC@.050" of 40.5 degrees which will quell the pre-detonation but raise my scr and my dcr. If I run the 62CC chamber heads with the same 1003 gasket (.041") then my squish will be even worse and counter productive to pre-det issues AS I'VE LEARNED THANKS TO YOUR ARTICLES RECOMMENDATIONS AND "TECHINSPECTOR1"! Unfortunately I am stuck with what I've got on hand except another cam option and I am trying to keep this car as much of a daily driver as possible and not have to run 2 degrees initial timing and lose the potential of the motor just because of pre-det and/or not enough money for fuel to run it. This is where I stand at this time but am open to plenty more information/opinions/expert advice on this matter. thanks again all.
  #22 (permalink)
Old 01-30-2013, 04:08 PM
I have the speed pro H345NCP .030", flat top, 4 valve relief Pistons. They are about 6 cc volume.
Yes, 60.2 currently but will more than likely change to my 62cc heads once the pressed in studs are removed to make way for my screw in studs and guideplates.
Block has been milled some. I am sitting .016" in the hole. Hope this helps you help me. Thank you!
  #23 (permalink)
Old 02-01-2013, 04:18 PM
Originally Posted by Joel78Vette View Post
I have a SBC 2 bolt-350 bored .030" over with 062 vortec heads (now 175cc intake runners and 60.2cc chambers) with stock valves (yes 3 angled), after-market springs (1.265" singles) set at 122#'s, 7/16" studs with guide plates; cast steel crankshaft, eagle rods, flat top, 4 valve relief, hyper-eutectic pistons; polished professional products cyclone intake (dual plane good to 5500 rpm's) topped off with a stock 650 thunder series edelbrock carb. The camshaft is a Howard's Race cam (retro roller)-214/218@.050", .488/.495" lift w stainless steel 1.6 full roller rockers. Quench is about .057". about .016" in the hole with a .041" gasket (1003, I believe). Static compression sits about 10:1 at 1700 ft above sea level. I have a full 2 1/4" hooker exhaust with 1 5/8" - 3" ceramic coated headers. A level 2 700r4 w 2200 stall converter and 3.55 rear gears on 27" tires (255/60r15). The block mains have been aligned honed and have studs vs. bolts. Good Hp and TQ numbers would be appreciated. Thanks, Joel
Nice combo, I'd say hp is somewhere in the 375 to 400 range around 5600 to 5800 RPM, torque around 390 to 410 about 3500 to 4000 RPM.
Pluses on everything, except the intake and carb and to a lesser extent quench.
Negatives are the intake and carb. The Edlebrock Performer RPM and a 750 Holley would give more top end power with very little sacrifice on the bottom end. I know the calculators on CFM for a 355 lead one to about a 600 to 650 cfm carb but you'd find the bigger Holley or Edlebrock/Carter will better support a 400 plus horse top end, if indeed you want to crack that somewhat of a bragging right barrier.
The squish/quench could have been tighter which would be more effective if it was .040 inch. But the compression really isn't that off, my calculator produces 10.3 Static with a rounding to 60ccs in the head and assumes 6 cc's in the pistons. The dynamic assumes a 5.7 inch rod and I calculate the Howards 110235-12 really doesn't close the valve tight on the seat till 61 degrees After Bottom Center. This is a long ramped cam from the .050 inch lift point on the intake being 266 at zero (or there abouts) and 213 from .050 inch tells you there's 53 degrees of ramp between those two points. Assuming the cam is symmetrical that's 26.5 degrees on either end of the lobe from .050 to zip. Subtracting that from my 61 degrees you get 35 (then take out 4 for the advanced grind nets 31 which I didn't do) which is pretty close to someone’s calculation of closing at .050 which would not take into the dynamic effect of the rising piston shoving high pressure mixture past the almost, but not quite, closed intake valve. This effect is nothing like flow benching intake flow at .050 inch lift with a pressure depression of 28 inches of water. This is more like where compression goes with a burnt exhaust valve, that's a substantial pressure loss, 'cause the piston is pushing mixture out. So anyway running my personal DCR calculator it drives an effective stroke of 2.79 inches which reduces the 10.3 SCR to a Dynamic Compression Ratio of 8.46. Certainly 93 octane unleaded burning in an L31 Vortec chamber ought to be good with this. Perhaps not ideal but certainly acceptable within the context of a street performance engine which at least for a DD can't be taken to the same operation/configurational edge that a race engine can be pushed against.
So I'd say this is a darn good effort. Well thought out; you're to be congratulated.
I’ll sort of PS this; where some claim to run less than .040 inch squish/quench, this gets risky in that one can easily bang the pistons and valves and at high RPM the piston to head structure. For a street engine that will wear and that includes the softening of the valve springs with age, running under .040 can result in unpleasant and expensive experiences.
Bogie
Last edited by oldbogie; 02-01-2013 at 04:28 PM. Reason: (then take out 4 for the advanced grind nets 31 which I didn't do)
355 sbc blackchevy3de Engine 14 01-25-2012 04:10 PM
383 HP and TRQ estimations? BigLeoRocks Engine 16 05-15-2010 06:53 PM
sbc 355 stepj19 Engine 8 07-02-2009 08:26 PM
355 sbc pena0724 Engine 3 06-08-2009 03:55 PM
What is a 355 SBC? frankenvette Engine 11 09-12-2004 07:59 AM
