355 with vortec heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2012, 12:05 PM
355 9.0.1 compression 170 cc vortec heads dule plan aftermarket intake roller tip rockers 650 Holley dp headers cam is jegs 465 lift 282adv lobe Sep 114 cam timming .50 is open Intake 3 atdc close 41 abdc then the exh open 51 bbdc closes -7 btdc what power will this setup make I'm looking for broad power low to mid hot street motor your thoughts thanks and a 5 speed trans 373 gears 26 tires
Old 12-22-2012, 06:09 PM
I have a358 Chevy dart angle plug heads vicktor intake 13 to one motor don't know what hp it has got it in a trade think I will try it in my s10 first
Old 12-22-2012, 08:04 PM
vinniekq2's Avatar
using propane for fuel?
Old 12-22-2012, 09:09 PM
got from a friend's stock car dirt track is there anyway to get it down from 13 to one he sed 450 hp today not having to changing pistons
Old 12-22-2012, 09:20 PM
vinniekq2's Avatar
could you write the next post in question form?
Old 12-23-2012, 08:07 AM
Can I run this motor on the streets with E85 we have it here
355 vs. 406 w/vortec heads cr480r Engine 35 12-22-2012 01:06 AM
Summit Racing vortec heads VS GM Performance Vortec heads jsm1847 Engine 3 05-29-2012 06:01 PM
Will a intake off vortec heads fit non-vortec heads nobody_1250 Engine 13 12-27-2010 05:02 AM
355 vortec heads comp xe268 build questions TX512 Engine 6 11-30-2009 09:07 AM
355 w/ vortec heads abas_abas Engine 11 03-24-2009 05:54 AM
