Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 vs. 406 w/vortec heads
  #22 (permalink)
Old 12-20-2012, 04:27 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
Originally Posted by F-BIRD'88 View Post
Its real simple. The dynamic compression ratio is based on simplictic intake valve closing point.
When for 1 is very hard to accuratily establish.
I call BS. The mfg will give you the intake closing point down to minutes and seconds if you ask for it and it's not that difficult for a home garage builder to find 1 degree.
2. the RUNNING engine's real in cylinder pressure has nothing to do with the cranking compression.
when its running at speed.
I call BS. Show your scientific data to support that statement.
In the real world, engines do not operate in a tightly controled environment.
Gas quality changes, operating temps change, air inlet temp changes widely.
The knock tolerance of a engines varies widely based on the actual operating conditions at any one time.
I call BS. What are you going to do, reach out into thin air and pick a cam?
As a general statement engines that operate in the real world with more than 10.5:1cr that are not computer electronic controled will be knock sensitive on even good pump gas reguardless of the cam used.
When things get hot they get hot.
I call BS. What data do you have to back up what you say?
For every internet guru that claims that you can do this and that there are 4 guy who found out how the real world really works.
You don;t pick a cam based on simple dynamic compression ( theory).
I call BS. Where's your data to prove what you're saying?
You cannot predict the cranking compression based on published cam specs.
These are not the true running open close specs of a RUNNING engine.
I call BS. Where's your data?
Your cam picks are always lame and wrong fo both power and .....
I call BS. Sounds like one punk's opinion to me.
[quote=F-BIRD'88;1625176]
Your power estimate are always wrong and lame based on over simplistic $20 computer programs and wrong inputs./[QUOTE]
In short you are full of BS,,,, SIR. have a nice day.
Again, BS. Just one punk's opinion.
That seems to be all you have is opinions with nothing scientific or mathematical to back them up. I call BS on your entire agenda.
Just for the record, I have PM'd you in the past and tried to make friends. My PM was never answered, leaving me to think that you are just a punk who is devoid of honor and integrity and chocked full of BS opinions.
