Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 355 vs. 406 w/vortec heads
  #29 (permalink)
Old 12-20-2012, 06:01 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by F-BIRD'88 View Post
Here is some data for your that pretty much matches what happens in the real world.
Daytona Sensors LLC - Tech FAQ Engine Tuning
Thank you for the article. I read it. While it addresses air fuel ratio and spark timing, it stops short of explaining what camshaft timing needs to be used to complement the max 10.5:1 static compression ratio. Could a guy supposedly use any cam he feels like using? That's what the article suggests. In other words, you could use a cam that closes the intake valve at 20 degrees and have the same results as another cam that closes the intake valve at 60 degrees. I call BS. If that's your "real world", I call double BS with sprinkles.
