-   -   355 vs. 406 w/vortec heads (http://www.hotrodders.com/forum/355-vs-406-w-vortec-heads-227376.html)
cr480r 12-19-2012 10:58 PM
I have my 355 apart and it needs a few more things than I had planned. Actually, it only needs one piston(skirt has a crack) and all the basic overhaul items. No big deal. I was just about to pull the trigger on all the needed parts, But then over the weekend I went to a garage sale at a neighbors house and saw he was selling a complete 400 core for $100. Supposedly he drove it home, but it smoked. I started thinking that if this 400 core was in fact useable I could gain 51 cubes with just some new pistons and the typical block machine work + balancing... the other stuff i need to buy anyways. The engine is used in my K30 truck that is mud raced and sometimes street driven. i could always use more torque. My new cam set-up is probably gonna be rpm limited by the lifters, so I am thinking the larger displacement may really help me. Just looking for some opinions on rather the potential gain is worth the cost. I have no experience with the larger small blocks. I dont have alot of money, but i could make this happen if its worth it.
my current combo is:
10.68 CR @ .038 quench (was planning to mill for 11.2)
062's w/stock valves bowl blended to 88% throat.
RPM air gap
750 DP holley
1.75 headers/3" pipes
10" converter (3400 stall)
street hyd roller lifters (recommended for 6200-6500 max)
new custom cam is 240/244 @ .05 108lca .535" w/ 1.6 rockers std. base circle. IVC 74 abdc.
went to a hydraulic roller for reliability, and i really hate setting the lash on a lifted truck. I already had appropriate springs.
old cam was solid tappet, 248/256 @ .05 106lca .550/.572"(net)
techinspector1 12-19-2012 11:30 PM
RPM air gap
750 DP holley
I wouldn't bolt L31 heads onto a 400 block and expect more hp. You can expect more torque up to the torque peak, but those heads, as good as they are, I don't think will feed 400 inches to the revs you are currently seeing with your 355. A 400 block deserves AFR 195's or 210's in my opinion. Scroll down here to 413 and 406 dyno tests.....
http://www.airflowresearch.com/chevy_dyno.php
cr480r 12-20-2012 12:26 AM
thanks guys i appreciate the input.
i am more concerned with the output than rpms... as long as i dont lose hp or go slower. I know that the rpms will drop with added cubes, but i have no idea how much so that where i need help. I originally had the solid valve train so i could "operate" it @ 7200... which was well past peak and ideal, but it helped me "hang on" with a 4spd truck that was often "inbetween" gears... It worked quite well in fact. But that cam lost a lobe and my new truck is auto trans so it can shift wherever it needs to.
Air Flow Research
very good stuff there. But unfortunately, i don't see them in my future. I know my stuff is less than ideal, but its what i have.
Originally Posted by F-BIRD'88 (Post 1624892)
Hyd cams are for the girlie man. ;)
i know, i know... :D the internet had me thinking the cheap solid rollers were failure prone. and its a pain to check lash on this rig.. gotta make the best of it now...
454C10 12-20-2012 04:46 AM
read this. Bigger heads on a 406 worth 60 hp with a moderately sized cam. Would be even more with a bigger cam.
Chevrolet 406 CI Engine Build - Chevy High Performance
Anything over 0.525" is a "Waste of lift" on vortec heads.
cobalt327 12-20-2012 08:30 AM
First things first- go get the 400 before someone buys it out from under you. If it's a good engine (block and crank mainly, stock heads are junk), it's well worth $100.
vinniekq2 12-20-2012 11:30 AM
The vortec heads will only support so much HP like Tech already mentioned.The 350 will make as much power as the 400 just at a higher RPM.The roller cam you bought will likely make power sooner than the solid you had.I bet the 400 will be all in by 5800- 6,000.
Work with Tech on the CR thats best suited to the fuel you will use.If you want more power then get better heads.
cr480r 12-20-2012 11:33 AM
its not hard to understand that a bigger engine would ideally have better heads.. Everyone knows that. I am just trying to figure out if my existing 355 combo would be worth adding cubes? or if its a waste of my time? I am considering a new short block, not a new engine.. So far i am getting opinions going both ways...:confused:
this is why i went with a custom grind. So I could reduce lift without buying new rockers... .535" is pretty close, and with potential lifter collapse and pushrod flex the valve may really only see .525:D
thats what started this lol.. i am sure its still there. not many chevy heads around here these days.. and its christmas time.
If i could make the same horsepower, and get a harder punch at launch rpms i would consider that worth it.. this rig is heavy. if the gain is substantial i can justify the effort. I understand the heads are the limiting factor, but i am not ready to upgrade. Besides aluminum heads usually get you thrown right in with the faster rigs... I would rather remain stealthy and give the appearance that nothing has changed.
vinniekq2 12-20-2012 12:02 PM
I dont see any improvement,unless lower RPM is an improvement?You can buy very good cast iron heads
ap72 12-20-2012 12:13 PM
like most people you probably don't want to hear this, but your cam is WAY too big. You'll make more power if you lose about 15 degrees duration on the intake and exhaust.
So many people overcam Vortec heads, they are good STOCK heads, they are NOT a race head.
To handle the cam you have those heads need to be ported out to the max, pick up about 25-35cc's of runner volume and maybe a larger valve after that.
Your combo really should have large port bowtie vortecs, not the tiny 062 vortecs.
cr480r 12-20-2012 01:02 PM
i know this. But how will less duration make more power?In my mind if the compression ratio is enough for the valve timing, and a narrow powerband is acceptable then where is the problem? i thought limited heads liked duration? My solid cam with "way too much lift" was stronger than the previous 355 combo was. it was 10:1 and a comp 280H.. some would say that cam was too big also.. so how did going even bigger gain? I know these are not race heads, but people do race with them. the roundy rouind guys make power with them. Trust me i wouldnt go this route again, but i own them, they have been freshened, and i dont mind doing more porting. This is not a street car... everything would be different if it was.. All i care about is the output from 3500-6200... I am not changing the converter, the heads, the cam, or the lifters.. so with that considered would a 406 short assembly help, hurt, or do nothing for me?
ap72 12-20-2012 01:31 PM
It will not hurt, and help a little, BUT your money would be better spent on a cam. If you're looking at 3500-6200 then a tight lash solid cam in the 235/240 range would be a LOT closer to what you need. For a hydraulic roller you'd want about 225/230 maybe a little more, but not much. As you can see your current cam isn't even close.
Restricted heads DO NOT want more cam, they work best with smaller cams and less compression. If you want more cam, compression, and RPM then you need a bigger head. For your RPM range on a 350 a 190cc port is about right- hence that is one of the most popular intake port sizes. Even then your cam would be too big though, a HR in the 235/240ish range would be about as big as you would want to go.
If you don't mind me asking, what cam company spec'd the cam you're currently using?
cr480r 12-20-2012 02:00 PM
another tight lash flat tappet was not an option for me. The truck often sits for long periods, and although they work fine for most i didnt want to risk another lobe failure. I feel the dry starts may have been a factor, as well as my springs. And In my new neighborhood a camshaft breakin with 3" exhaust isnt a good idea. I dont wanna name drop the cam company on a open forum. not til after i use it anyways. Initially the rep suggested a 236-240 cam on a 110 lca. staying under .500-525" lift for the vortecs. But when we discussed this being a max effort with my existing parts and usage we decided to change it. After I stressed I had a loose converter, as well as a true 10.7 CR he decided to bump it up one step for pump gas. The LCA was tightened to 108 because i have no vacuum acessories. He felt my previous 106 was too tight for the 5.7 rod length? the cam lobes are .501" with 1.5 rockers and it was the closest lobe master he had in this duration range that would let me keep my 1.6 rockers without the lift going sky high...
ap72 12-20-2012 02:22 PM
For fully ported Vortec heads the rep's initial recommendation was about right. Go figure.
cr480r 12-20-2012 02:28 PM
Originally Posted by F-BIRD'88 (Post 1625092)
My 406 screams with my vortec heads on it.
revs right up to 6700rpm. pulls like a frieght train. well past 6000 rpm.
The vortec heads are ported but not max ported by any means.
The solid roller cam that you have will work really well in the 400 with your vortecs.
re valve lash:
I trust you were not trying to set the lash "hot".
Its a lot easier to set the lash "cold" a lot more pain free.
You won;t hate doing it either.
Set the lash cold about .004" tighter than the hot lash spec.
I'd reconsider using that cam in your 400 w the vortecs. IMHO it is just right for your 400 w vortecs.
Ap72 has no clue.
The Hyd roller you got is just dandy too. Just not my preference.
These cams are just right.
If you liked the vortec heads on your 350, you are going to really like them on a 400SBC.
Use a -18cc dished piston on your 400 for pump gas compatability with 64cc heads.
A flat top piston 400 with vortecs will need about a 100 octane fuel to keep it happy.
A bit much for pump gas.
the old cam was flat tappet and it wiped a lobe. I was lashing cold, but its a pain in this truck while basically sitting on the motor. The old truck had no fenderwells so i could sit on the tire and go through them very easily. I went hydraulic because my springs were too weak for a solid roller, and i read many horror stories of cheap roller lifter failing with street use. pressure fed lifters are alot of money.
with my intake valve closing at 74 on the new cam i figured i could up the compression to 11:1.. i dont remember the intake closing on the old cam but with a 102 installed ICL it was trapping over 200psi with no pump gas issues. I always spiked the fuel before races, but i did plenty of street flogging on pump 91. always had 32* total timing. I always figured the stall speed and tight quench made it more forgiving
techinspector1 12-20-2012 03:26 PM
Originally Posted by F-BIRD'88 (Post 1625132)
Don't buy into the dynamic cr BS.
Its is way to simplistic.
Yeah, I can see where it makes way more sense to just pick a cam out of thin air and hope for the best. Holy Jesus H. Christ !!!!!!!!!!!!!! :boxing:
You seem intent on calling BS to most everything I write, so I'm gonna start bitin' back. You don't know all the answers and neither do I.
Can't you give some sound engineering reason as to why you don't like DCR or is it just that I happen to champion it and you have to try to call it BS just because I like it.
Let the biting back begin, here and now. I'm tired of you and your punk attitude. Several board members have PM'd me and asked why you are the way you are toward what I write, so it's not just me. Others see your attacks also. So, either lighten up or I'm gonna have something to say about every damned thing you write.
For the rest of you, here's an article written by Pat Kelley that might explain some of the process of choosing components....
http://cochise.uia.net/pkelley2/DynamicCR.html
