358? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2012, 06:59 PM
358?
small block chev 358 cube
3.905 bore 3.750 stroke, does anyone have any experience with this combo?
or is this a mythical mistake?
i'm curious if it would work and if it would out torque a 355.
thanks in advance
Old 10-22-2012, 07:57 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
If you want to build a 358, don't use odd bore sizes, there is no need unless you are building a Nascar engine. Using odd sizes require special pistons, rings, etc. that is not worth the extra cost. Race engines are special breeds especially when you're running for $$$$, then every ci and tweak counts to get the advantage. For a street motor and less money, go with a good known combo.
Old 10-22-2012, 08:51 PM
vinniekq2's Avatar
thats not a mystery motor,its a long stroke LS motor,standard stroke is 3.622. A longer stroke has an advantage for making power at a lower RPM.The arm in longer for leverage,not very much longer.You can go as long as 4.1 stroke in some LS blocks
Fuel Injected 358 sbc zildjian4life218 Engine 2 10-13-2009 12:50 AM
SBC 358 Build for Economy zildjian4life218 Engine 7 10-12-2009 08:38 PM
