36 chevy sealed beam headlights - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2007, 04:56 PM
I'm want to put sealed beam lamps in original 36 chevy buckets. Are lamps available for this?
Old 02-02-2007, 06:30 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You can still get sealed beams....the larger ones for the two healight systems and the smaller size like used in the four headlight systems. Measure your buckets and then go to the parts store and measure the sealed beams. If the smaller size fits...you will have to use the low beam ones.
Old 02-03-2007, 08:18 AM
If you want to mount the sealed beams behind the original lenses and doors, you can take the mounting buckets for the sealed beams out of a junker and mount them in the original buckets for your 36.
You'll have to make a filler plate around the sealed beam to "finish" off the installation. Your lighting will be better than original BUT not as good an uncovered lamp. The double refraction of the light through the sealed beam lens then through the original lens makes for a fuzzy kind of light.
The ideal would be an original or reproduction reflector and a modern bulb like those used in late model composite headlights, OR a smooth no-faceted lens for your original bucket with the selaed beam behind it.
Old 02-12-2007, 05:17 PM
Thanks for the ideas. That gives me something to think about. I was hoping someone made a light that would fit. I guess I'll have to get to work.
Old 02-18-2007, 08:00 PM
acr acr is offline
Look at what Bob Drake & Speedway sell. My '36 Plymouth buckets used Drakes Reflector & Quartz Halogen Bulb kit for the '37-39 Ford, #78-13027-QK-12 & they fit & work fine.Speedways clear lens Quartz Halogen 7" light for street rods, #910-64150 might also work.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Chevy Thunder and stonedchihuahua Jon Hotrodders Site Suggestions and Help 56 03-14-2004 06:47 PM
36 chevy body Shigzy2000 Body - Exterior 3 02-04-2004 12:22 PM
36 Chevy doors Jerry Borrasso Body - Exterior 5 09-03-2003 01:32 PM
rear end for my 36 chevy truck leroux Transmission - Rearend 0 06-13-2002 07:44 AM
