Start a wiki article on any hotrodding subject:
Then, others help to build it.
Read and write hotrodding articles in the Crankshaft Coalition Wiki.
See 150+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-11-2007, 08:03 PM
Caddad65 Caddad65 is offline
'36 chevy sedan rear suspension
Anyone know of another company other than Chassis Engineering that makes a rear suspension kit for my '36 chevy sedan. C.E. is $500 + so I'm just trying to research other options.
Thanks,
Mike
Old 12-12-2007, 04:28 AM
Deuce Deuce is offline
Deuce's barnstarLast wiki edit: Wheelbase database
Not owning a 36 Chevy ... I do not ... BUT I will say I have used Chassis Engineering products for many years on Fat Fender Fords ... and their stuff works great, is well engineered and well worth the $$$ IMHO
Old 12-14-2007, 10:20 AM
pasadenahotrod pasadenahotrod is offline
There is nothing wrong with the stock rear suspension on those early Chevy's at all. Dual rear springs is the simplest and easiest to make up and repair parts are available. Your local spring can rearch the springs for you if they are drooping and even make new leaves if necessary.
Old 12-14-2007, 07:07 PM
advanced design's Avatar
advanced design advanced design is offline
Remember, this is to be fun!
Mike,
I have a '35 Chevy Master coupe that has a CE kit in the rear. If you want to go C4 Corvette check out Progressive Automotive. If you are thinking of doing a 4-link check out Suicidedoors.com. Just ordered their 4 link universal which is very well built and very reasonably priced.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "'36 chevy sedan rear suspension"
'55 Chevy Swap to 4 Bar Parallel Suspension Merton Beebe Suspension - Brakes - Steering 19 11-18-2007 06:46 PM
wHAT SIZE TIRE AND WHEEL WILL FIT UNDER THE REAR OF MY STOCK SUSPENSION 55 CHEVY SEDA POP BOND Suspension - Brakes - Steering 1 02-25-2007 08:56 AM
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 06:50 PM
FatMan Wonderbar Rear Suspension Mega Suspension - Brakes - Steering 7 10-21-2005 08:42 PM
Rear Suspension Bind Desert Rodder Suspension - Brakes - Steering 4 05-08-2002 09:29 AM
