Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 03-16-2004, 01:33 PM
spuds1956's Avatar
spuds1956 spuds1956 is offline
36 chevy stock axle rework info needed
Have 36 chevy standard with stock I beam front end. Would like to put some 49-54 repo spindles (from Speedway Motors) that accept disc brakes. What is the better way to go . Should I drill my orignal axle to .867 from stock diameter to accept the larger diameter king pins?
Or should I use a stock 36 king pins and put a smaller inside diameter bushing in the 49-54 repo spinldes to accept the smaller 36 chevy king pins? Has anyone tried this? Or is this just a bad idea? (donmck1950@aol.com) DON
Old 03-16-2004, 03:25 PM
Thom Laybourne's Avatar
Thom Laybourne Thom Laybourne is offline
Search I-Beam
Do a search in this forum on I-Beam. You should find the name of the company up in Fresno, CA that does nothing but. Very good to talk with and great information. One of the last projects on my trucks suspension.
hr41pearl
Old 03-16-2004, 04:30 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: 36 chevy stock axle rework info needed
Open up the axle, lots less work.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
