36 chevy truck wiper motor help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2012, 11:21 AM
Last journal entry: Getting there....I think
I am looking for a newer electric wiper motor set up for my 36 chevy truck. Thank you guys!
Old 03-10-2012, 02:31 PM
35terraplane's Avatar
wiper motors
Get a hold of Newport Engineering, They have motors for most cars and trucks. I don't have the # but that's what the nets for.
Bob
Old 03-10-2012, 02:35 PM
poncho62's Avatar
Wiki Edits: 5
I used a VW bug electric motor and arms in my 51 F1...just had to shorten the cross arm a bit
Ontario Rodders
Old 03-10-2012, 02:44 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
For my '33 I used Specialty Power Windows and wipers.
They don't use linkage it's a push-pull cable thang making it fittable to most applications.
vicrod
Old 03-10-2012, 05:36 PM
EOD Guy's Avatar
I used Detroit Speed delay wiper system, super easy install and comes complete with everything needed including a fuse, billet knob etc....... they are proud if it tho' to me it was well worth the money.
Old 03-15-2012, 03:17 AM
You can search it online.there are many information.
Old 03-15-2012, 08:39 AM
cadmanof50s's Avatar
68 Camaro Convertible, 327 RS
I think in that vintage you probably have a 6 volt system?
If so it will probably cost you a little mopre than the guys with the 12 volt setup.
I don't know of anyone who makes the motors that run directly off 6 volts.
I had to use a power converter in my '48 Cadi in order to update the wiper system to electric. A little more costly and a few more wires and gadgets to deal with.
Vic Brincat
Old 03-15-2012, 03:56 PM
Joe G's Avatar
Registered user
Your truck just has a single wiper, right? If so I would be looking at Mighty Wiper. They are available in 6v or 12v, use a simple on/off switch, and draw less than one amp.
Hope this helps....
Old 03-16-2012, 09:20 PM
Your truck originally had a vacuum wiper system. There are several aftermarket units. The suggested mighty wiper is one choice.
Pat
Old 03-17-2012, 08:57 AM
Wiper motor
Pat
Would you guys read the OP, he wants an up grade not 6 volt or vacuum if I read it right.
Bob
Old 03-23-2012, 08:25 AM
use a 6v battery
a friend said just use a 6v battery and charge wen needed for wiper and heater blower motor hay if it work's and cheap
Old 03-23-2012, 08:32 AM
in the old day's
in the old day's my dad just tap haft way and was 6v do they make a battery that have 12v and 6v tap on it spudman
Old 03-23-2012, 08:59 AM
electronic voltage reducers
classic haulers.com has voltage reducers for motors up to 15 amps part#3223 for $59.50 ea phone 1-877-252-1948 page 39
Old 08-09-2012, 10:13 PM
496CHEVY3100's Avatar
Big boys wear Bowties
Last journal entry: ,
36 chevy wiper motor
Hope this helps jim carter truck parts has different versions of what you are looking for electric motor use your arms part #ww350 for 67.50 or compkete change over wipers for both sides motor transmission (arms gear box )very well made easy to install part#ww355 $345 i installed the deluxe kit on my 50 chevy pu 2 years ago no problems part # listed above are for 1934-1946 or 47 1st design phone #800-226-1919
Old 08-23-2012, 12:10 AM
I have a mighty wiper in my '37 coupe and have had one in a '35 pickup. Both worked great and were easy to install, and not expensive.
Jim
Windsheild Wiper Motor - 1980 Chevy Truck LaPlace Electrical 1 10-28-2011 09:40 PM
what kind of wiper motor for a 51 chevy pick-um-up new_rat_rodder General Rodding Tech 8 02-10-2009 07:54 PM
looking for wiring for 2 speed wiper motor on 68 chevy pickup trkitchens Electrical 1 03-20-2008 07:12 PM
Chevy AD Truck Wiper Motor Question bigfred1958 Interior 1 11-12-2004 04:49 PM
'55 Chevy OEM electric wiper motor PrimeMover Electrical 11 01-28-2003 12:22 AM
