Bill,
Sorry I dont have any pictures. I just made it so it would fit the openning and contoured it to resemble the front seat. If the top back where it joins rear shelf is curved you will have to cut a board out to fit contour and then attach to plywood. Just lay straight edge across openning and make you a cardboard pattern to cut out board Sounds like your seat you have now is either a thin foam or a hard foam. I cut opennings in the plywood for webbing where a persons bottom would sit for more cushioning. And use good foam in different density layers to get it comfortable. Use a less dense foam for the back rest. Hope this helps. You can email me at
wernerupholstery@yahoo.com Tom
