Hi gang,
Well, I've uncovered some bad frame damage. I put my feelers out for a replacement but until then, repair of the original is in order. I put in the CE parallel rear leaf kit and their crossmember kit. The front crossmember was badly cracked and a previous repair (cobbled POS) warrants replacement. I found one on eBay so I was a happy camper. The spreaders are non-existant and instead of welding up some square tubing, enterained buying the re-pops from Precision Coachworks. The side rails are bad as is the front outboard body mounts, also available from PC. Will I get satisfactory rigidity with the buttwelded frame repair pieces? Short of ordering up the rich man's double-throwdown boxed tube aftermarket frame. Am I heading in the right direction???
Thanks,
Cam
Thanks,
Cam
