Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 36 ford rear wishbones
Old 02-19-2002, 04:43 PM
roadstar roadstar is offline
New Member
the 40 style rear has spring mounts as part of the axel housing and should work with the setup you discribed. the 35/36 rear wishbone has the spring mount on the end of the wishbone so this lets you use any rear you want and still have buggy spring and wishbone type rearend setup. I hope that helps you some, you might have to look at both to get a better idea. good luck..
