36 Ford rearend selection???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 10:48 PM
Hi, I have a 36 Ford Coupe (chopped) and I plan on a 289 with a C4 along with a Chassis Eng cross member. Why a 289, because I have one! With the basics described what rearend should I be looking for? I have been told Maverick but is that the only choice? Thanks, Dave
Old 04-17-2006, 11:09 PM
57 to 59 Ford car and a few others. Chassis Engineering lists the better donor rear ends for their kits....With the 289 ........strength should not be a real issue..
Old 04-17-2006, 11:18 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Here is a site that give you some info and help you with your decision:
http://50chevy.freeservers.com/Suspe...tml#Suspension
By the way is that a 3 or 5 window coupe?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-18-2006, 12:58 AM
dinger's Avatar
I used a Maverick v-8, 5 lug, had to move the spring mounts a bit. Street Rod Engineering makes a kit for this. Look at my album. Dan
Old 04-18-2006, 07:38 AM
Dinger, wish I had seen your frame work before I did my coupe and pickup. Would have save a lot of brain cells and may have had a better setup for a lot less work!!! Your project is looking good. I hope to take my coupe on a 500 mile shake down cruise after the just completed EFI project on it.
A 67 thru 77 Bronco rear end is perfect for the 35-40 Fords, but the 9 inch would be over kill and the most common 3.50 gearing would beg for an OD tranny.
Trees
Old 04-18-2006, 09:11 AM
rearend type
Thanks for the advice. It is a 5 window project. Plan on a trunk, not a rumble. Dave
ford rearend 55post Transmission - Rearend 3 01-16-2006 05:36 PM
36 ford greggfar Introduce Yourself 6 12-26-2005 08:25 AM
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 11:30 PM
Ford Rearend Bob Moren Transmission - Rearend 2 10-15-2005 07:37 PM
36 ford club cabrio wkbc62446@aol.com Body - Exterior 4 11-07-2002 10:14 AM
