36 Ford Truck steering column length suggestions please - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2012, 05:29 AM
New member here. My pop has been a street rodder from the age of 13 - so that's over 60 years now. His love of cars rubbed off on me, but my old cars are pretty stock except for performance upgrades.
I'm helping dad finish up his 36 Ford Truck street rod. It's got a MII front, steel cab, not chopped but the firewall has a 2" setback, Chevy 350, TH350, floor shift.
Right now I am shopping tilt steering columns and would appreciate suggestions for overall tilt column length and drop height. The u-joint will be looking for a 1" 48 spline output from the column. So, if any of you have experience with the 35/36 truck and can make suggestions, I'd sure appreciate it. Dad's not doing great, and we'd love to get this truck done soon.
Also, if I decide to put the ignition cylinder in the dash and not on the column (to save some $), will we screw up the Ron Francis wiring kit currently installed (for steering column ignition)?
If you need pictures or more info about this build please let me know.
Thanks!
Old 07-20-2012, 06:58 AM
WELCOME ... to Hotrodders.com.
I suggest a Chevrolet/GMC van tilt column. Small, no key and the P R N D d2 d1 are on the column. Neutral safety switch also.
The correct length and has easily found parts and support if needed.
DEUCE ... Moderator
Old 07-20-2012, 08:40 PM
Cool. I'm gonna search for a thread to see if someone has ever fab'd anything to get the column shift indicator to work with a floor shifter with a secondary rod.
1936, column, ignition, length, truck
56 ford truck steering column... Hwyhogg Suspension - Brakes - Steering 1 09-07-2011 09:37 AM
Steering column length help lt1tyrell Suspension - Brakes - Steering 2 09-22-2009 10:20 PM
steering column length. willys41 Interior 1 05-25-2008 03:58 PM
steering column length fattyford Suspension - Brakes - Steering 1 02-06-2006 01:59 PM
Steering Column Length onegoodi Suspension - Brakes - Steering 1 12-24-2002 11:04 AM
