'36 Olds Door wood - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2006, 07:58 PM
'36 Olds Door wood
I don't know if this should be in the interior or exterior discussion but here goes. I have a 4dr 1936 Olds Sedan. The wood in the back doors are rotted beyond use as a pattern. Does anyone know of a company that might have or make wood for '36 Fisher style bodies? Also in 36 Chevy went to an all metal door. Is that interchangeable with the Olds since they were both made by Fisher Bodys?
Thanks
Old 07-24-2006, 08:21 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Your probably gonna have to wing it without a pattern. A lot of the guys do not use wood....they use square steel tubing ( Thin wall) and fab it up. Might have to make pie cuts here and there where there are curves involved and just weld it in.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
olds 455 oldscutlass General Rodding Tech 7 01-01-2005 11:34 AM
frames 37 chevy going on a 38 olds 38 old coupe Suspension - Brakes - Steering 0 05-24-2004 01:45 PM
Camaro-T/A motor mounts and Olds Questions Hot_Rod_Faith Engine 8 01-15-2004 01:01 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
